Anyone recharged their A/C? - Mustang Evolution
Old 04-16-2006, 03:15 PM   #1
What are the steps to recharging the A/C? What are the tools that I need to get?
Old 04-16-2006, 03:54 PM   #2
97Stallion's Avatar
Re: Anyone recharged their A/C?
All you need is a kit of r-134a from wal-mart. It comes with a valve dealio that you hook up to your lines.
Living one day at a time!
Old 04-16-2006, 04:27 PM   #3
Dom
Dom's Avatar
Send a message via AIM to Dom
And make sure you grab the can with both hands when you do it.
Old 04-16-2006, 04:40 PM   #4
Why is that?
Old 04-16-2006, 05:16 PM   #5
RGR
Send a message via AIM to RGR
Why is that?
It will freeze your hands, notice his
It's easy, simple directions on the box. I've done several.
Originally Posted by Flex:
You are the true cam master dude...
RGR is offline   Reply With Quote
Old 04-16-2006, 05:20 PM   #6
Man I totally would have done it too
Old 04-16-2006, 06:12 PM   #7
Well I bought one of those kits... and put the gauge on to read the pressure... and it was in the warning area of the gauge... did I check the wrong one? Its the only service port I could find on the car for the A/C on the line that goes from the A/C Compressor to the evaporator thing.
If it is in the warning area does that mean the A/C compressor is bad?
Old 04-17-2006, 04:19 PM   #8
Region: Hawaii
I think there is a low pressue and a high pressure side. You want the service port by the accumulator/dehydrator thingy(love the techincal jargon)torwards the back of the engine bay on the pass side, by the shock tower. This is on a 01 gt though, yours maybe different.
99 Atlantic Blue V6- SOHC 4.6 swap, Tremec 3650, 8.8 rear end/ Flowtech Ceramic LT headers, off-road x-pipe, Spintech side exit exhaust. K&N drop in filter, removed snorkel, 18x10, 18x9, Anthracite Bullitt Replicas 295-35's, 265-35's. Eibach Pro-Kit springs, M&M Camber Plates
wrecked2001 is offline   Reply With Quote
Old 04-17-2006, 04:39 PM   #9
97Stallion's Avatar
Well maybe you're compressor is not getting electricity. Look on the from of your AC compressor, you should notice a little triangle thing on the front. Turn on your ACA and it should engage the clutch and spin the triangle thing. does it?
Old 04-17-2006, 08:06 PM   #10
Fishers Stang's Avatar
Brent, here is a pic. also: "11. Back off the valve handle on the charging kit and screw the kit onto the refrigerant can, making sure that the o-ring or rubber seal insdie the threaded portion of the kit is in place. WARNING: Wear protective eye wear when dealing with pressurized refrigerant cans.
12.remove the dust capfrom the low-side charging port and attach the quick-connect fitting on the kit hose WARNING: DO NOT hook the charging kit hose to the system high side! (now cliff notes) : turn the car on, let it warm up to normal, turn AC on, fill with refrigerant never add more then 2 cans, let the 2 sides = the same temp, use a wet hot towel around the can to help prevent frosting)
Charles
Old 04-24-2006, 07:08 AM   #11
Its pretty easy to do, I have one of the setups with a guage and adapters for the high and low side, but now they make a bottle with a line that hooks right up, I think it might have a small guage setup built in, its even cheaper.
Justin Starkey
2007 Shelby GT500 705RWHP/708RWTQ
2000 Mustang 3.8 A4 TT 450RWHP/475RWTQ 10.996@127 17psi stock 3.8
2006 F250 CC 4x4 6.0L 14.3 @ 93
2006 Mustang 4.0 M5 Vortech 13psi 395RWHP/374RWTQ wife's car
justin00stang is offline   Reply With Quote
Old 04-26-2006, 05:10 PM   #12
RGR
Have you done it yet Brent???
Getting HOT even up here!
08:57 PM
