Car starts missing when A/C or Defroster is on.... - Mustang Evolution
Old 04-16-2006, 06:15 PM   #1
Any idea what would cause this? The car starts missing terribly when I turn the A/C or the Defroster on......
Old 04-16-2006, 06:33 PM   #2
Kiljosh's Avatar
Re: Car starts missing when A/C or Defroster is on....
Bad alternator? Maybe killing the charge to the battery and the extra accessories drain it to the point the car misses? A long shot but all I can come up with.
Old 04-16-2006, 07:34 PM   #3
bbunt302's Avatar
It's likely that the A/C clutch has gone out or A/C compressor is frozen up.
Try getting someone to sit in the car while it's running while you listen and watch under the hood. Watch the accessory belt where it turns the A/C compressor pulley and see what happens when they turn the A/C on.
Scary stuff.
Old 04-16-2006, 08:16 PM   #4
Looks like the A/C Compressor is froze up
Turned the car on... my mom turned the A/C on and bam.... the pulley on the a/c compressor turned one rotation and froze.
I got another A/C compressor in my garage.... is it something I can replace or am I going to need to have someone else do it?
Old 04-16-2006, 08:23 PM   #5
bbunt302's Avatar
You might need to just take it somewhere to have it done. All the old refrigerant will need to be flushed. It's a fairly involved project. If you know a little about working on A/C stuff, you may be able to handle it yourself though. Mine is frozen up too, but now that I'm getting another car I think I'm just going to get rid of the A/C all together.
Scary stuff.
Old 04-16-2006, 08:34 PM   #6
After last summer and being stuck in ATL for 3 hours in 98 degree heat.. I am not getting rid of that A/C lol
Old 04-16-2006, 11:31 PM   #7
I liek gramer
WhiteStang99's Avatar
^ WERD. all caps for a damn reason too.
Old 04-17-2006, 08:19 AM   #8
i dont really use my ac much
Old 04-17-2006, 04:45 PM   #9
97Stallion's Avatar
You can replace it yourself. What you need to do is slowly remove the screw holding the piping to the compressor. You will hear the refrigerant (sp?) start to bubble out with the oil. You might want to get some towels to protect your engine from the oil that's going to spit out. After it stops, remove and replace the compressor and then recharge the system. Easy as pie!
Living one day at a time!
Hot starts 67mustang97 1996-2004 Mustang GT 2 07-23-2010 06:55 AM
Rear Defroster wiring? MustangScott Pre-2005 V6 Mustang 0 07-08-2010 08:57 PM
When car starts, idles to almost kill... Cajun JungleBoy 1979-1995 Mustang GT 29 07-25-2008 08:33 AM
Can't Use Lights or Defroster or 01 Mustang goes nuts!! twnations Pre-2005 V6 Mustang 4 12-04-2005 08:59 PM
new pics of the car, can u tell whats missing? Bane- Pictures and Videos 7 08-26-2005 10:04 PM
02:27 AM
