04 3.9L A/C fan not working - Mustang Evolution
Old 03-13-2010, 06:31 AM   #1
On my mustang, I have lost the fan control. It is either all on or all off, the first 3 settings do not work. I installed a good size stereo system, and that is when it stopped working. I have checked the fuses they are all fine, I have checked all the connections on the fan control know and all looks fine, I could use any help I could get.
thanks
jsoles is offline   Reply With Quote
Old 03-29-2010, 07:25 PM   #2
Re: 04 3.9L A/C fan not working
OK, I take the fuse out and it does not work at all, so with the fuse in it just goes either all on or all off.
Old 03-30-2010, 07:32 AM   #3
hmm my 01 had an issue where the air was blowing kinda like that, ended up being a sensor that went bad. You may can run codes just to see if anything is there (even though its not a check engine light)
There is a fan controller that may have went out of have some kind of wiring cross that caused it to get to much power or something and popped some other random fuse.
Sup mustang fan supersnake09 New Member Introductions & Greetings 13 03-27-2009 11:25 AM
Anyone here a fan of.... 1234 The Bar 17 01-07-2009 01:55 PM
As much as I'm not a Honda fan... wiarumas The Bar 13 04-21-2005 06:41 PM
fan switch tire Pre-2005 V6 Mustang 5 04-02-2004 09:39 AM
10:43 AM
