Lower Springs verse Coil Overs??? - Mustang Evolution
Old 04-23-2006, 01:18 PM   #1
Region: Alaska
I just put some 245/40zr18 (front) and 265/35zr18's (rear) on my 05 V6 Mustang. I want to close the gap between the tire and fender, but I was wondering since it is more noticeable on the rear than the front would just getting a rear coil over kit work, or should I just get all new lowering springs?
Sonic Blue is offline   Reply With Quote
Old 04-26-2006, 06:18 PM   #2
dark's Avatar
Send a message via AIM to dark Send a message via Yahoo to dark
Re: Lower Springs verse Coil Overs???
coilovers = better handling
I don't own a mustang at the moment
dark is offline   Reply With Quote
Old 04-26-2006, 06:25 PM   #3
KyleUSAF's Avatar
Send a message via AIM to KyleUSAF Send a message via MSN to KyleUSAF
i'd definately drop the front and back if your going to drop it. Full coil overs would be nice if you can afford them.
Originally Posted by Darkshadow
I could say nothing for my complete awe. He then. confidantly, purchased the gallon.
KyleUSAF is offline   Reply With Quote
Old 04-26-2006, 11:21 PM   #4
Region: Alaska
KyleUSAF, are you in the Air Force?
Old 04-27-2006, 05:04 PM   #5
I liek gramer
WhiteStang99's Avatar
^ he's not at the time, but I believe is applying to the academy.
Old 04-29-2006, 07:57 PM   #6
Rick0636's Avatar
The reason you have the gap there between your tires and the fenders is this, your tires aren't as tall as the stock ones that came on your car! Might be hard to beleive, but I bet if you measure the tire height on the stock wheels and tires that came on your 05 you will find those low profile 18s to be shorter than your stock ones, and you also probably messed up your speedometer at least some. You might have to buy a chip to fix that. I am former Air Force, Supply, Mat. Facilities Spec, Feb 70 til Apr. 73, don't envy you being in Alaska man!
The stock GT 17s that came on my 06 pony pkg have very little of that gap at all.
Old 04-30-2006, 11:03 AM   #7
Region: Alaska
Rick,
I worked out the math on the tires, with the new ones I lost an inch and I want to make that up inorder to put the springs on that I bought. But up here having a lowered car means lots of dragging along the roads. I used the Diablo Tuner to get the speedometer set right so thats not a worry. I wish I could load up a new picture I added Roush Side skirts and painted calipers. You can turn the outside of a V6 into GT style before you know it.
Eibach Lower Springs- 1" Drop austindk 1996-2004 Mustang GT 3 02-03-2010 10:28 AM
Performance Lower Springs jwalthersoccer Pre-2005 V6 Mustang 19 01-04-2010 04:06 PM
Eilbach Pro-Kit coil springs? fasternu_674 Pre-2005 V6 Mustang 8 10-01-2007 09:44 PM
coil overs vs. lowering springs STEVE Pre-2005 V6 Mustang 6 06-13-2004 02:36 PM
!!!!Coil Overs!!!! !*!STANG!*! Pre-2005 V6 Mustang 12 10-13-2003 06:19 PM
08:04 AM
