Gears - Mustang Evolution
Old 03-15-2010, 01:44 PM   #1
Gears
hey guys im looking at putting a 8.8 in my car...i see that there is a 3.73. 4.1 and a 3.55... im looking for a quick off the line but also strong quarter... what would be the best... please help..
Stumper is offline   Reply With Quote
Old 03-15-2010, 01:47 PM   #2
Re: Gears
Is it an auto or manual? Most people go with 4.10's in their automatics and 3.73's in their manuals.
19Delta is offline   Reply With Quote
Old 03-15-2010, 02:23 PM   #3
upton7's Avatar
Re: Gears
might as well go 4.10
Old 03-15-2010, 02:30 PM   #4
Re: Gears
My car is manual, 08 , v6... So 3.73, or 4.1.. is there much difference...Will i notice the difference when im driving...compared to my stock
Old 03-15-2010, 02:31 PM   #5
Re: Gears
You'll lose a few mpg's when on the highway, but you'll accelerate quicker due to the gears. I would personally go with 3.73's.
Old 03-15-2010, 02:33 PM   #6
upton7's Avatar
Re: Gears
I agree if its your daily driver keep it reasonable with 3.73.
Old 03-15-2010, 04:50 PM   #7
Re: Gears
Yah if you're a manual go with 3.73's. 4.10's will be too tall if it's a dd. The mileage loss isn't that bad between the two, maybe 1mpg or so on the highway, but I'd still recommend 3.73's. You'll have a much stronger powerband over the stock gears.
Old 03-15-2010, 05:27 PM   #8
Re: Gears
Okay thanks guys so lets say i just want a rocket... would 4.1 be any better?
Old 03-15-2010, 06:25 PM   #9
blackonblack's Avatar
Re: Gears
better. but i wouldnt consider it a "rocket"
2004 3.9L v6
Black on black on black
MAC Cold Air Intake, 4.10 gears + T-Lok, SCT Tuner, dual H piped flowmaster super 40's
blackonblack is offline   Reply With Quote
Old 03-15-2010, 07:01 PM   #10
big show 98's Avatar
Re: Gears
with a 5spd 3.73
big show 98 is offline   Reply With Quote
Old 03-15-2010, 07:21 PM   #11
Re: Gears
You know, I was thinking about the differences between 3.73's and 4.10's.
Generally, the taller the gear, the more your top end will decrease while rpm's increase. 4.10's will cause your top end to decrease more than 3.73's or 3.55's. But I'd say that's only if you're pushing some considerable hp and reach higher top end speeds. (v6's are speed limited to 115) I wouldn't classify a near stock v6, nor a bolt on v6 at that level. So you would probably be fine with 4.10's in a manual. It might just help your top end. 1st gear might be tricky regarding wheelspin but you should be able to adjust. The loss in mpg's should only be around 1-2mpgs tops on the highway. I would say the performance benefit from the 4.10's would outweigh that slight loss in mpgs.
Either gear ratio, remember to have a tlok installed with the gears and have the car tuned afterward...so your speedometer is correct.
Old 03-15-2010, 08:25 PM   #12
Re: Gears
Old 03-15-2010, 08:49 PM   #13
Re: Gears
Thanks sonic and all u other guys who posted... big show do u notice a nice get up and go difference with ur 3.73
Old 03-15-2010, 10:34 PM   #14
Re: Gears
It was a big change for my car, but I went from 2.73 to 3.73. If I could do it over again I would go with the 4.10's if rpms & mileage isn't a factor for you. I turn 2650rpms @ 75mph. My gas mileage didn't change much on the highway. The car runs great but it begging for more gear. This my advice for an auto car. 5spd I still say 3.73.
Old 03-15-2010, 10:58 PM   #15
OsirisGuy's Avatar
Re: Gears
I've been told, altough I haven't yet personally confirmed that the 05+ T5 transmission has a smaller first gear. In order to compensate for the drop a lot of owners are going with a steeper rear axle gear, that is 4.10 over 3.73.
This may help a little as well
http://www.mustangevolution.com/forum/t158093/
OsirisGuy is correct
OsirisGuy is right
2002 Mustang GT
Old 03-16-2010, 08:25 AM   #16
Re: Gears
Thanks guys... Looks like ill be ordering the 4.1 to try her out... I knew i picked this forum for a reason...
Old 03-16-2010, 09:17 AM   #17
SaleenFiend's Avatar
Re: Gears
T5 with 3.73s was plenty for me when I drove one.
NEED HELP WITH GEARS!! Motive 4.10 gears? Cant find ford racing? Camaro Eater Pre-2005 V6 Mustang 4 06-23-2010 11:57 AM
3.73 gears tim11 Pre-2005 V6 Mustang 5 10-25-2005 09:21 AM
4.10 gears powerhungry966 Pre-2005 V6 Mustang 7 10-23-2005 07:53 PM
gears 8.8 or 7.5 strike1980 Pre-2005 V6 Mustang 5 08-01-2005 12:05 AM
Factory Gears Vs. Racing Gears tire Pre-2005 V6 Mustang 0 07-21-2003 05:02 AM
02:19 PM
