P&P'd upper and lower... - Mustang Evolution
Old 04-25-2006, 09:51 PM   #1
DarkShadow's Avatar
Send a message via AIM to DarkShadow
Alrighty guys, this is my plan, let me know if you think the gains would be cost effective.
I want to get some ported and polished upper and lower intake manifolds. I will either order them from supersix or see if I can find a good place locally that does it. (I've heard of one, but I don't know where it's located). Would it be better to just get a new set of intakes, or ,if I can find a reputable shop with experience, would it be just as good to take them locally to have the stockers P&P'd?
I would also be getting either a 65mm or 70mm TB to go with this. I know the stock TB is 60mm, so would the 65mm be worth bothering with? Or would the extra money for 5mm more be worth it for the 70mm?
Also since I am forced induction, what are the hp and tq gains you would expect to see out of this. TMA turbo on 10 psi with the power in my sig on an auto split port. I would not be getting the heads and cam as I don't want to tear into the block until I have another car as a back up, so that is out of the question for right now.
Also, would any of you local guys know of a good machine shop that has experience doing this work? Like I said, I know there is one, but I don't know where it's at. I think it was in Huntsville...
Thanks.
DarkShadow is offline   Reply With Quote
Old 04-25-2006, 10:00 PM   #2
Re: P&P'd upper and lower...
Thanks.
Huntsville Engines and Performance Center. It is where I am having my shortblock assmebled. I am 100% they can do the porting.
Old 04-25-2006, 10:36 PM   #3
I_luv_HP&trq's Avatar
Send a message via AIM to I_luv_HP&trq Send a message via MSN to I_luv_HP&trq
more airflow means more hot air crammed into your intakes. you would also lose some velocity. To get max performance you would want your heads matched... I'd find a performance shop that has a flow bench you could test it on before getting into it.
but hey i could be wrong.
99 Cobra: flowmasters, 18x9.5 cobra R's, soon to be tuned and geared. daily driver
99 V6:in avatar, Mac Cai, true duals/flowmaster 40's ,UDP, custom tuned, bullitt suspension 18" wheels...taken by mother nature
I_luv_HP&trq is offline   Reply With Quote
Old 04-26-2006, 07:23 AM   #4
DarkShadow's Avatar
Hmm...where is this place located and do you have a phone number? I must admit, I'm a little gun shy after the "previous experience" which I told you about at the track...
Also, what ya'll think about getting the 65 or 70mm?
Old 04-26-2006, 07:28 AM   #5
DarkShadow's Avatar
The whole point of forced induction is more air.
The air is already intercooled, so yeah it's hot but it's probably about stock temps if not a little lower.
I MIGHT loose some velocity, just because it's not all trying to cram into a smaller space, but the added air flow would more than make up for it. Especially if I have a turbo ramming it in there like, well you know, the sort of things Nate likes to do...
I know the matched heads would help, and so would a cam. I don't have the added time or money to be without the car for the week it would take me to instal a power pack. The rest will just have to wait until I have a back up car and this one becomes the weekend project car. So just intakes for right now...
Old 04-26-2006, 07:31 AM   #6
I would get them from someone like rpm or supersix since you know they have a good bit of experience doing them. Might as well just save up and get heads/intakes/cam all at the same time, or better yet... buy a spare motor block and start building it.
Old 04-26-2006, 07:41 AM   #7
DarkShadow's Avatar
^than would you like to help me get them installed in a maximum of 2 days?
Old 04-26-2006, 08:13 AM   #8
lol. Once bit of advice I can give you is: Do it right the first time even if that means waiting to get it done. Dont expect it to happen overnight and do the research so you know what you are getting into. Buy your stuff from a very good place even if it costs more (you get what you pay for even if the part is more you may get superior service and backing behind it) and when you mod you create problems, the more you mod the more crap brakes/messes up so get used to it and expect it.
I tried to go cheap on a couple things and boy... did it turn around and kick me in the butt...
Intakes are not hard to install at all~ just takes time and a bit of knowledge~ If you buy a block and build a motor you can take your sweet time.
Old 04-26-2006, 08:51 AM   #9
DarkShadow's Avatar
No, the intakes are easy. It's the whole power pack that I won't be doing until I have another car. There's nothing wrong with the block I have. So once I have the second car, I'll just build the stock one.
BUT THAT'S NOT WHAT I'M DOING RIGHT NOW!
I'm only doing the intakes for now, so anyway. I've kind of been leaning toward just getting them from supersix because I know they've done it, but that's sort of what I said about the last event.
Old 04-26-2006, 12:30 PM   #10
I personally would be saving my money for now
Old 04-26-2006, 02:16 PM   #11
DarkShadow's Avatar
I understand what your saying. It's just going to be a while until I can do everything. And I'm stuck on the 350hp number, so I'm going to do the intakes to bump me up to that number thereabouts, and then not do anything else for quite some time.
Old 05-04-2006, 06:25 AM   #12
RGR
Send a message via AIM to RGR
Didn't you PM me thru V6Power about a cam Robert?
IMO you should get a set of intakes from RPM, Mik really gets alot from a
stock upper and you could use that type porting. SSM usually suggests 1
of their SSX uppers, fine piece but mucho $ and IMO you don't need it (yet).
SSM and RPM have Core Exchange so you will not have the "local" problem
of downtime. Also, a V6 shop will do much better on the porting job, than a
local place. Us V6 guys have been doing these much longer, in fact I did the
very first one ever, in April of 1999. +13 RWHP/+16 RWTQ. For a mild P&P.
Originally Posted by Flex:
You are the true cam master dude...
RGR is offline   Reply With Quote
Old 05-04-2006, 12:30 PM   #13
DarkShadow's Avatar
Uh...no but that is my name strangely enough. Unless I did it with one of my many other personallities... I'm not a member of v6power, but I should be.
If I were going to get some intakes, I'd want to get top of the line that way I'm not limited later. I plan to REALLY build this car in a few years.
Old 05-04-2006, 02:28 PM   #14
RGR
I guess it was the TMA 10# kit they were using that threw me for a loop
Good numbers Robert, you can make that thing really rock IMO!
Old 05-04-2006, 03:03 PM   #15
DarkShadow's Avatar
Huh?
Old 05-04-2006, 03:26 PM   #16
RGR
I want to get some ported and polished upper and lower intake manifolds...
...TMA turbo on 10 psi...
...I would not be getting the heads and cam as I don't want to tear into the block until I have another car as a back up, so that is out of the question for right now...
The person I was helping also has these parameters
...hence my confusion!
Old 05-04-2006, 10:44 PM   #17
DarkShadow's Avatar
Ah.
P&P Upper & Lower -Spilt Port Herbstang Mustang Parts for Sale and Wanted 11 10-10-2006 09:09 AM
Gauging Interest P&P Upper & Lower Split Port Herbstang Mustang Parts for Sale and Wanted 0 09-22-2005 08:45 AM
Ported Upper or Lower first? ntc432 Pre-2005 V6 Mustang 20 05-06-2005 07:04 AM
upper and Lower intakes coolstang Pre-2005 V6 Mustang 8 02-12-2005 11:26 AM
need pics of p/p '94-'98 upper/lower tire Pre-2005 V6 Mustang 8 02-27-2004 10:55 AM
06:50 AM
