Cruise Control Out! - Mustang Evolution
Old 04-26-2006, 07:42 PM   #1
Question Cruise Control Out!
What causes cruise control to go out? I bought my stang back in 05 and the cruise control was already out on it, I want to fix it but im not really sure on what it coulb be that needs fixed...any ideas?
Debras96stang is offline   Reply With Quote
Old 04-27-2006, 09:05 AM   #2
slvr2000stang's Avatar
Re: Cruise Control Out!
The first thing to check would be the fuses for it.
Look in your owners manual for their locations.
There are two fuse boxes, one under the hood & one under the dash on the drivers side.
Custom Delk motor now DOA
2003 SVT Lightning #1059 of 4270
2000 Vert 4R70W
Only buy from vendors that test and stand behind their products
slvr2000stang is offline   Reply With Quote
Old 04-27-2006, 11:20 AM   #3
Herbstang's Avatar
ID:	12913 Power for the cruise control comes in through the DRL/Fog/Horn fuse in the engine compartment fuse box. It then goes through the horn relay (don't ask me why) , through the clockspring in the steering wheel and then to the cruise control switch.So, if the cruise control and the horn doesn't work, it is likely the horn relay or the clockspring assembly is bad. If the horn does work, then the clockspring assembly or the cruise control switch is bad.
Old 04-28-2006, 10:02 AM   #4
Ok well the horn works just fine so I guess its the clockspring assembly doesnt work...what would I have to do to fix it? Is this an expensive part or is it decent? Would it be best to get a pro to fix it or is it something easy to fix? I dont really need the cruise control but dang it is much more easier to use on the highways around here!
Old 04-28-2006, 10:25 AM   #5
does anyone have an owners manual that might be able to send me the setup for the fuses? I dont have a manual and I have no idea what fuses are what, any help with this would be awesome! I need to atleast know what fuse it is that works the cruise control so I can change it to see if thats why my cruise control isnt working.
Old 04-28-2006, 11:41 AM   #6
Herbstang's Avatar
Try looking here Mustang FAQ - Engine Information I would suggest buying a chilton repair manual Automotive repair manual catalog from RepairManual.com.
Have you done any resent work on the electrical ?? Check for a vac. leak
Old 04-28-2006, 12:52 PM   #7
no, I havent had the car for long, I have had it for a year now, I havent touched anything electrical on it except for like the stereo system I have in it and putting new lights on the front. Other than that nothing has been touched electrically. I bought the car with out the cruise control working so there is no telling hw long it hasnt been working.
Cruise control upton7 General Car Discussion 12 05-01-2010 05:52 PM
Cruise Control Sticking meteorachick Pre-2005 V6 Mustang 19 06-19-2008 05:39 PM
how to remove cruise control buttons jimmy_beaner Mustang Audio & Video 7 06-01-2006 01:55 PM
tv cable or cruise control ??? fastang11 Pre-2005 V6 Mustang 4 12-25-2005 01:30 PM
1995 3.8 cruise control? v6Stangin95 Pre-2005 V6 Mustang 7 09-24-2005 03:02 AM
05:34 AM
