Looking for 2 295/40sr18's... - Mustang Evolution
Old 04-26-2006, 11:27 PM   #1
Region: Alaska
Looking to fill in the tire/fender gap. Springs are taking me down 1.6" and the 295/40/18's will get me the rest of the way. Anyone know a good place to get this larger tire? The 295 is to fit the 18x10 deep dish bullit rim.
Sonic Blue is offline   Reply With Quote
Old 04-27-2006, 09:30 AM   #2
Re: Looking for 2 295/40sr18's...
40 is to tall for the sidewall, I would go with a 35 maybe even 30 depending on how the math works. If you screw with the overall diameter then you mess up your speedo.
Old 04-27-2006, 11:51 AM   #3
Zim
You want to **** me?
Zim's Avatar
I agree with spector, get the 295/35/18s. I have them on my car with and they fill the fender nicely. If you want a bit more drop, maybe remove one of the isolators from the perches.
I like toys
Old 04-27-2006, 01:03 PM   #4
and remember as the sidewall closes the gap with the fender lip it also raises you off the ground an equal amount.
Old 04-27-2006, 01:30 PM   #5
bbunt302's Avatar
Remember guys this is an 05 and they come with an overall taller tire.
My car came with 235/50/18s which is a 27.25" tire. A 295/40/18 is a 27.29" tire so it is actually nearly a perfect height. Just don't expect it to be any "taller" than stock, because it won't be. It's actually almost exactly the same.
This my friends is why you can put 20's on these cars and they look like 18's on the older models.
Scary stuff.
Old 04-27-2006, 01:53 PM   #6
true, didnt even think about the 05s... stupid ford
Old 04-27-2006, 04:24 PM   #7
KyleUSAF's Avatar
Send a message via AIM to KyleUSAF Send a message via MSN to KyleUSAF
good call bbunt...i just assumed it was a 94-04 when reading the post
Originally Posted by Darkshadow
I could say nothing for my complete awe. He then. confidantly, purchased the gallon.
KyleUSAF is offline   Reply With Quote
Old 04-28-2006, 03:22 PM   #8
Region: Alaska
The stock tire diameter was around 26 something, with the new tires and rims it dropped it down to 25.3 on the rear. So I wanted to put more meat on the rear and gain an inch diameter inorder to put lowering springs on the rear to drop the fender down 1.6". It was some math but I think it will look good with the bigger tire and drop. Any other suggestion before I begin the surgery?
Old 04-28-2006, 10:56 PM   #9
Region: Alaska
Here is what I am working with. Had the side skirt painted to match, just trying to fix the gap.
Anyone need cheap 295/35/18s? Zim The Bar 14 04-21-2006 10:30 PM
10:03 PM
