Uhh.. True or not true? - Mustang Evolution
Old 04-28-2006, 06:49 AM   #1
Ibanezplayer272's Avatar
Send a message via AIM to Ibanezplayer272 Send a message via MSN to Ibanezplayer272
Originally Posted by Guy on mustangforums.com
in the 4R70W auto tranny, first and second gear are manual valve bodies, so you can go 1-2-O/D off D to O/D on D, or you can just do a D-2-D which will firm up the shift as well, tranny was made for it, just make sure you get the tranny flushed every 30k or so, and make sure that it gets done before 75k or just forget about it
2007 Windveil Blue Mustang GT
Mods : Intake, Stubby antenna
Rolls are for fat chicks
Ibanezplayer272 is offline   Reply With Quote
Old 04-28-2006, 07:00 AM   #2
Dom
Dom's Avatar
Send a message via AIM to Dom
Re: Uhh.. True or not true?
I wouldn't jerk around any transmission. Auto or 5spd.
Old 04-28-2006, 07:52 AM   #3
thats what the old AOD guys used to do, your car will run NO faster shifting it, you paid for an auto, you have an auto, dont treat it like a manual. Leave it in drive and go, the car can shift much faster than you can.
Old 04-28-2006, 04:04 PM   #4
Im on the completely same page with you guys.
Old 04-28-2006, 11:46 PM   #5
DarkShadow's Avatar
Send a message via AIM to DarkShadow
I've NEVER understood the whole manually shifting an auto thing...why? I know some people didn't have the option at the time you were looking (like me), but if you're going to shift and auto, why didn't you just get a manual? There's no point and you're just taking away the only advantage the auto has: it can shift faster than you can.
DarkShadow is offline   Reply With Quote
Old 05-03-2006, 01:34 PM   #6
Bane-'s Avatar
the only time you have to shift an auto is if it has a FULL manual valve body. other then that leave the damn thing in D and go.
Old 05-03-2006, 02:05 PM   #7
I used to do the D-2-D thing just to get it to chirp into 2nd...then I got a chip.
Old 05-03-2006, 02:55 PM   #8
Danger Dude's Avatar
Guys I hate to bust your bubble but with a performance auto tranny like I do people who drag race will use first to start of when they hit the magic rpm number they shift into drive. If you have a built motor even with a shift kit and tune the tranny wants to shift you before the engine is ready especially from 1st to 2nd. as far as wear and tear on the auto that is a moot point considering my auto will outlast your manuals and can handle more HP than most of your manuals.
Old 05-04-2006, 06:05 AM   #9
RGR
Send a message via AIM to RGR
The old AOD shuffle was worth a solid tenth of a second at the strip,
if you shifted at the right RPM (higher). Now the reprogramming of
the newer auto's will do this for you, much better than you can do.
But it needs reprogrammed.
Originally Posted by Flex:
You are the true cam master dude...
RGR is offline   Reply With Quote
Old 05-04-2006, 08:11 AM   #10
cant you get a chip to correctly shift the car for you where you want it to
Old 05-04-2006, 02:36 PM   #11
RGR
Yes, on the newer trannies. I thnk all since (and including) the AOD-E can do this.
AOD was non-electronic, it used a vacuum referenced modulator and
TV (kick-down) cable.
Old 05-04-2006, 02:46 PM   #12
I had my tuned car tuned by Jerry to shift where I wanted it but since I have installed my BV heads I find myself still building HP in first when it shifts automatically So I start in first on the track. That is also why I lost a V6 shoot-out semi final race at track day 2 years ago. I LAUNCHED IN 2ND DOOH!!!!!
Old 05-04-2006, 04:00 PM   #13
A tune can do the same. Corey you have a built automatic of course it going to handle more power than my stock manual.
Is this true? chris098 Pre-2005 V6 Mustang 38 02-17-2007 12:45 AM
True Duals Taywi Classic Mustangs 10 12-09-2006 03:30 PM
could it be true oaktonarcher The Bar 7 01-26-2005 07:18 PM
this is true STEVE The Bar 103 10-17-2004 11:38 AM
this true STEVE The Bar 4 07-18-2004 11:32 AM
10:23 PM
