hp? - Mustang Evolution
Old 04-29-2006, 10:19 PM   #1
yellowscreamer's Avatar
Send a message via AIM to yellowscreamer
Question hp?
how much hp can you get out of a v6 mustang 03, with or without a superchager? thanks
yellowscreamer is offline   Reply With Quote
Old 04-29-2006, 10:40 PM   #2
Danger Dude's Avatar
Re: hp?
Well it all depends on the money spent
But here are some actual numbers from around the V6 stang community
N/A V6 somewhere around 280-300 would be about tops
Supercharged /Turbocharged at or around 500HP has been reached by a few
Typically people 99/04 V6's are in the 220-260 RWHP with major N/A mods and Supercharger/turbocharged cars 330-400 but there are a few well above this
Old 04-29-2006, 10:58 PM   #3
Dark02Pony's Avatar
Send a message via AIM to Dark02Pony
Re: hp?
4.3 stroker kit with forged internals, h/c/i kit, LTs o/r midpipe, good flowing catback, intake spacer, 70mm tb(of course the upper manifold being port matched), bigger MAF, cold air intake, UDP, tuner w/ dyno tune, 3.73 w/ tloc if your manual or 4.10 w/ tloc if your automatic, shifter(if manual), torque converter, tranny cooler,aluminum driveshaft would = 1 badass N/A mustang.
http://img.photobucket.com/albums/v6...rtandgrill.jpg
Operation: Evolutionization.......Member #3
Originally Posted by MonteCitan
Ford Motor Company = FoMoCo..
what does that make Honda Motor Company????
Originally Posted by Nicole
Mineral Gray is such a hott color. Much better then orange
Dark02Pony is offline   Reply With Quote
Old 05-01-2006, 07:22 AM   #4
Dom
Dom's Avatar
Send a message via AIM to Dom
Re: hp?
See this thread.
Old 05-01-2006, 09:04 AM   #5
slvr2000stang's Avatar
Re: hp?
Corey summed it up perfectly.
Custom Delk motor now DOA
2003 SVT Lightning #1059 of 4270
2000 Vert 4R70W
Only buy from vendors that test and stand behind their products
slvr2000stang is offline   Reply With Quote
Old 05-01-2006, 09:07 AM   #6
Re: hp?
Its about money, and how much you want to spend. The faster you go the more you pay.
Old 05-01-2006, 10:50 AM   #7
powerhungry966's Avatar
Send a message via AIM to powerhungry966
Re: hp?
just dont take the "cheaper" route.. once u start that crap.. it will come back to haunt u guaranteed
1989 coupe 5.0 yeessur.
"Shake n bake"
powerhungry966 is offline   Reply With Quote
Old 05-01-2006, 10:54 AM   #8
Re: hp?
yup, if you cut corners you spend more in the end than doing it right in the first place... ive learned that lesson myself.
Old 05-01-2006, 12:00 PM   #9
Re: hp?
If you ever decided to get freaky with your engine and do real engine work I can only stress one thing. DO NOT SKIMP ON INTERNAL ENGINE PARTS. Only get the quality bearing, seals, gaskets, bolts and for GOD'S SAKE NEVER SKIMP ON THE VALVETRAIN. The #1 reason for high performance engine failure is a weak valvetrain. You need quality valves, springs, rocker arms and keepers and all necessary hardware.
Old 05-01-2006, 01:28 PM   #10
Re: hp?
definatly ^^^^^
Old 05-03-2006, 04:08 PM   #11
97Stallion's Avatar
Re: hp?
That sounds just like my car
Living one day at a time!
Old 05-04-2006, 01:08 PM   #12
Re: hp?
heads/cam/intakes/tune/boltons would be a nice boost over stock... but no warranty (you probably dont have the oem one anymore anyway)
10:41 AM
