High beams - Mustang Evolution
Old 03-19-2010, 08:03 AM   #1
Rascal's Avatar
Unhappy High beams
got a 2000 v6
ok so i was driving home last night and flipped my high beams on and it went pitch black lol. high beam light on the dash lights up but i have no high beams....
only fuse ive found for the high beams is under the dash. its a 20 amp and its fine even switched it with the cig lighter cause i knew it work and still nothing... is it possible that both my high beams blew at the same time? maybe a relay? i have no clue
i also just switched the stock battery terminals to brass ones yesterday dono if this would have anything to do with it but just throwing it out there..
Rascal is offline   Reply With Quote
Old 03-19-2010, 09:15 AM   #2
Re: High beams
well the bulb is a dual filament, it could be that they are both busted~ you can use a power tester to see if the high beam power line turns on (has power on the wire)
Old 03-20-2010, 08:51 AM   #3
Rascal's Avatar
Re: High beams
pulled the bulbs a few min ago there blown.. never would of thought that i figured it would be like 1 in a million that both would blow at the same time
thanks
Is this dude high? iwannagofast 1996-2004 Mustang GT 12 09-26-2009 11:34 PM
The High Came and Went bluemustang The Bar 28 03-01-2007 02:33 PM
reving high red pony V6 Pre-2005 V6 Mustang 3 03-03-2006 12:58 PM
A little high? n8r The Bar 10 02-13-2006 01:14 AM
Projector beams ttpancakes Mustang Audio & Video 17 07-18-2004 08:00 PM
02:03 PM
