Fender Rolling - Mustang Evolution
Old 03-19-2010, 02:03 PM   #1
Fender Rolling
Would i need to do any fender rolling if i lower my 01 2", i am planning on running 18" wheels with this drop? Any help would be appreciated
xcxm049 is offline   Reply With Quote
Old 03-19-2010, 02:53 PM   #2
Re: Fender Rolling
This is a good question, one of which I know well...
The entire issue of needing to roll the rear fender all depends on the rims and how they are setup.
You need to figure out the rims backspacing, once you do this you can take the rim width and subtract the backspacing from it. The number thats left can be no more than 3.5in (MAYBE 3.75 inches).
If you are less than or equal to 3.5in then you are fine and no fender rolling is needed (unless you have on heck of a budge in your sidewall of your tire). If you are above 3.75 then expect to need to roll the rear fenders.
This is what I see on my 03 cobra, should be just about identical on your car, I have an IRS rear end thats different by a little but overall aim for no more than 3.5 and you should be fine.
Old 03-19-2010, 09:15 PM   #3
Re: Fender Rolling
Brandon, you have to remember the IRS sits differently than a SRA car. I had to roll my fenders but I'm lowered more than 2" and run a 295 width rear tire.
To the OP, you shouldn't have any problem if you are running anything smaller than a 295 on a normal offset wheel.
Old 03-19-2010, 09:54 PM   #4
SaturnMan8227's Avatar
Send a message via AIM to SaturnMan8227
Re: Fender Rolling
well if you get the proper size tire along with the right offset of wheels (back spacing) you should not have to roll the fender. remember when plus sizing to any wheel/tire it is very important to get the correct size tire as this will also effect fuel economy and your speed read outs (mph).
example a 195/55/15 upsizes to 205/40/17
SaturnMan8227 is offline   Reply With Quote
Old 03-22-2010, 07:33 AM   #5
Re: Fender Rolling
whats the IRS vs SRA difference as im not sure, i knew there was some difference but didnt know how much
Rolling smog check Scut95 The Bar 3 04-01-2009 10:38 PM
Rolling shots........ Thomas91169 Pictures and Videos 12 12-12-2008 01:19 PM
Rolling rear fenders GTBrad Mustang Wheels & Tires 25 08-05-2006 11:37 PM
I'm rolling on dubs now Brent The Bar 39 06-10-2004 07:29 PM
08:19 PM
