it actually is good to use with a supercharger/turbocharger. It cools the intake temp rather good. Still... its about how much you can take~
Over time N20 in my opinion is bad, it may take a LONG time depending on how good the engine is build but in the end... its bad. If you only use it EVERY now and then it will be fine, heck the first couple shots may clean the motor a bit anyway.
As long as you get a good tune, nitrous is just fine for the motor. Its when people are running lean conditions that it causes problems. There's various safety features such as fuel pressure cut-off switch, WOT switch, window switch, etc that make nitrous safe as long as the user doesnt get greedy and use more than the motor can handle. Using a small 25-30 shot with a supercharger or turbo is fine... it cools the air and the intake temps are much lower.
the sensor constantly adjusts to keep it in the sweet spot, it is constantly going to rich and to lean thats its job.
Related Threads
Mustang Evolution Forum
2.1M posts
50.8K members
Since 2003
