Strut Squeak - Mustang Evolution
Old 05-02-2006, 05:59 AM   #1
Strut Squeak
I've recently develpoed a squeak everytime I hit a bump that comes from my front right wheel well. I bounced the car and believe it is coming from the strut. Is there anything else that could be squeaking up there? Also if it is the strut does that mean that it's bad or is there another possible cause such as dirt somewhere etc. Thanks
-Denver
2002 Mineral Grey GT, 5-speed: MGW short throw, JLT CAI: SOLD
2002 Electric Green V6, Auto: SOLD
greenpony02 is offline   Reply With Quote
Old 05-02-2006, 06:18 AM   #2
Danger Dude's Avatar
Re: Strut Squeak
Have you recently lowered your car??
Old 05-02-2006, 06:20 AM   #3
dark's Avatar
Send a message via AIM to dark Send a message via Yahoo to dark
Re: Strut Squeak
if no, how many miles on your suspension and are they hard driven miles?
I don't own a mustang at the moment
dark is offline   Reply With Quote
Old 05-02-2006, 06:34 AM   #4
Re: Strut Squeak
No the suspension is stock. I have about 60,000 miles on the car (got the car with 25,000) and I would say that I am pretty gentle on the car.
-Denver
Old 05-02-2006, 07:01 AM   #5
Re: Strut Squeak
Actually it could be dry tierod ends or any number of suspension parts that could squeak.The best thing is take to a place with a lift that will do free inspections and be able to lube anything that squeaks. I mentioned lowering because typically when you lower the tie rod ends change there movement inside the rotating ball in the end of the rod. This new motion will sometimes track over a dried grease area and cause a squeak.
Old 05-02-2006, 07:34 AM   #6
Re: Strut Squeak
check the tie rod ends and the bushings on the front sway bar as well as the strut. Greeze em all if they are not dry rotted.
Old 05-03-2006, 10:38 PM   #7
Dom
Dom's Avatar
Send a message via AIM to Dom
Re: Strut Squeak
Mine does the exact same thing. I just got used to it. Nothing seems to work to stop it.
Old 05-04-2006, 08:25 AM   #8
Re: Strut Squeak
define "nothing" if you kicked the tire and gave up then your right
Old 05-04-2006, 08:41 AM   #9
Re: Strut Squeak
now i'm starting to hear it from the other side too. I need to get this baby greased up and hope that's the problem. I really don't want to replace the suspension right now but if i have to i might just have to upgrade:chin:
-Denver
Old 05-04-2006, 09:21 AM   #10
Dom
Dom's Avatar
Re: Strut Squeak
I greased the tire rod ends. Noise came back the next week.
Old 05-04-2006, 11:13 AM   #11
Re: Strut Squeak
when my 97 did this my friend at ford greezed the ball joint really good with some little needled shaped greeser, i think he may have got down under the ball joint and what not as well. It stoped it.
Old 05-07-2006, 10:03 AM   #12
megax29's Avatar
Send a message via AIM to megax29 Send a message via Yahoo to megax29
Re: Strut Squeak
i got the same problem. i also got about 60k and it squeaks out of both side in the front i'm pretty sure its the shocks. i hear it when i brake, accelerate or turn or when there's a break on the street. I'll try greasing my **** up and will follow up. One more thing does my car have shocks or struts or both, how does that work?
V6 Midnight Black
CAI w/ K&N Filter, Tokico Complete Suspension kit, Single Flowmaster w/ turndown, GT rear sway bar.
megax29 is offline   Reply With Quote
Old 05-07-2006, 11:56 AM   #13
Re: Strut Squeak
Front struts, rear shocks. I did some greasing and i definitly think it's the ball joints not the struts. I think I need something like the "needle thing" spectorV was talking about because I can't seem to get the grease were it needs to be to fix the problem.
-Denver
Old 03-09-2010, 12:09 PM   #14
Strut Squeak??
So, I have a 1998 Mustang GT Convertible. I noticed last night that when I am taking off from a stop or something like it I hear a squeak coming from the passenger side rear wheel area. I noticed this after going down a muddy bumpy road. I have never heard it before but do now. Any ideas on what this could be?? Its getting on my nerves...
SuperDave2010 is offline   Reply With Quote
Old 03-09-2010, 01:21 PM   #15
Re: Strut Squeak
thread is closed due to being VERY old. You have a thread that you just started that will get all the attention, no need to have two threads split up about the same issue.
06 Rattle/ Squeak in front. 99ford Pre-2005 V6 Mustang 3 02-10-2010 08:09 PM
A/C squeak Foxone General Mustang Discussion 9 11-22-2009 02:01 PM
Rear Axel Squeak a3705872 Pre-2005 V6 Mustang 2 11-19-2009 07:36 PM
body kit squeak Warfire80 Mustang Audio & Video 9 11-15-2005 11:20 PM
Rear Squeak....Please Help!!! drzeusd Pre-2005 V6 Mustang 3 10-20-2003 02:44 AM
06:30 AM
