Emissions... - Mustang Evolution
Old 05-02-2006, 10:54 PM   #1
Send a message via AIM to Scottiedont
Emissions...
I have to go take my car in for Emissions...when i put my Cold Air Intake in, my SES light came on, i tried to clear the codes, and it worked, but a few miles later it would come back on again...and i was told that i would not pass emissions...does anyone know what i could do or if i did something wrong?...all the connections are tight nothing loose...i was told maybe it was upside down, i havent tried to do anything about it yet, i wanna get more ideas on what i could be first
-scottie
Scottiedont is offline   Reply With Quote
Old 05-02-2006, 11:26 PM   #2
Re: Emissions...
Take it to Autozone and have them tell you what the code is.
Old 05-02-2006, 11:50 PM   #3
Re: Emissions...
I had my guy that put my exhaust on hook it up...and he told me the code was from my intake
Old 05-03-2006, 12:02 AM   #4
Re: Emissions...
Need to be more specific. The MAF is on the intake... there are a few connections to it and then you got the sensors on the TB that go bad...
How is the car running?
Old 05-03-2006, 12:32 AM   #5
Re: Emissions...
I posted this question on my other mustang forum site...and this is the response i got....
"For emissions testing, take the intake off, put the original back on and disconnect your battery for about 15 minutes to clear the code.
After that, I dunno. Might be possible that your new intake allows more airflow than the ECM can accomodate and you might be running too lean.
That would require enriching the air/fuel mixture (i.e. a tune)"
but all i was told was that the code came from my intake, cuz i have a after market one on there
Old 05-03-2006, 05:09 AM   #6
Danger Dude's Avatar
Re: Emissions...
I have never heard of a cold air intake causing problems unless there is a problem with the MAF or the temp sensor. You probably have a problem with one of those items.
Old 05-03-2006, 07:28 AM   #7
Dom
Dom's Avatar
Send a message via AIM to Dom
Re: Emissions...
I think you just forgot to plug something up or tighten something down. We all do it.
Old 05-03-2006, 07:31 AM   #8
jimmy_beaner's Avatar
Region: Iowa
Re: Emissions...
I've never heard of a CAI blowing a code... what if you disconnected the battery for 15 minutes with the CAI on? Maybe that'd help reset the computer and clear the code?
Old 05-03-2006, 07:48 AM   #9
Re: Emissions...
check for air leaks and make sure everything is hooked up, ive never seen a problem with one if installed right.
Old 05-03-2006, 07:49 AM   #10
Re: Emissions...
on some there is a hole that is on the back side, it may or may not be used, make sure you dont have a hole just sitting there open letting air in.
Old 05-03-2006, 10:35 PM   #11
Dom
Dom's Avatar
Re: Emissions...
There is no CAI on earth that's gonna allow more air flow than the MAF can handle.
Old 05-04-2006, 12:10 PM   #12
Re: Emissions...
the kind with little blades that spin do
X-Pipe and emissions Mustang GT HO 1996-2004 Mustang GT 23 01-08-2009 11:50 PM
ugh emissions.... Scottiedont Pre-2005 V6 Mustang 5 06-01-2006 09:57 AM
Emissions and LT headers I_luv_HP&trq Pre-2005 V6 Mustang 11 12-23-2005 03:47 PM
emissions baxterbee7 Regional Mustang Discussion 2 07-11-2005 08:42 PM
Emissions test Turkish Pre-2005 V6 Mustang 4 07-10-2004 10:36 AM
09:44 PM
