Want to Increase Gas Efficiency - Mustang Evolution
Old 05-07-2006, 03:07 PM   #1
I have a '99 ford mustang v6 3.8 and I'm wanting to know how to increase fuel efficiency..
what would be the best bang for the buck mod I could do?
Would a cold air intake help?
Osalcido is offline   Reply With Quote
Old 05-07-2006, 05:45 PM   #2
dark's Avatar
Send a message via AIM to dark Send a message via Yahoo to dark
Re: Want to Increase Gas Efficiency
modifying your stang will make fuel efficiency worse
just keep your foot off the gas
I don't own a mustang at the moment
dark is offline   Reply With Quote
Old 05-07-2006, 06:01 PM   #3
bbunt302's Avatar
Not all mods will hurt, for example, underdrive pulleys can actually help gas mileage. I've heard people say that a CAI will help too, although I kinda question that one. If you do a lot of driving in the city and little on the highway, gears can also help slightly.
Scary stuff.
Old 05-07-2006, 07:46 PM   #4
One of the best ways to improve and maintain fuel efficiency is to maintain the car properly. Your car being a 99, I would recommend (if this hasn't been done recently) changing your spark plugs, wires, cleaning your MAF sensor and your TPS sensor (using non-contact electronics cleaner), changing your fuel filter, and running a few over the counter cleaners through the car. Running an injector cleaner through the car periodically will help, at least it helps mine. I do that about every 10k or so.
As far as mods, UDP's will lead to a slight increase in gas mileage, driving with the windows up and no a/c will help if you can stand it. If not, it's better to drive with a/c off and windows down than windows up and a/c on. At least this is what I've observed.
Another little thing is to check and maintain a constant tire pressure in all 4 tires.
Old 05-08-2006, 07:59 AM   #5
Dual exhaust may increase MPG slightly too.
Airing up your tires to 35-40psi is important as well. I like to run 40 in the front and 32-35 in the rear.
A special tune that decreases pumping losses can increase mileage by 1-2MPG.
Justin Starkey
2007 Shelby GT500 705RWHP/708RWTQ
2000 Mustang 3.8 A4 TT 450RWHP/475RWTQ 10.996@127 17psi stock 3.8
2006 F250 CC 4x4 6.0L 14.3 @ 93
2006 Mustang 4.0 M5 Vortech 13psi 395RWHP/374RWTQ wife's car
justin00stang is offline   Reply With Quote
Old 05-08-2006, 08:02 AM   #6
Nite-Mare's Avatar
I've observed the opposite, but I'm in a GT. Don't know if that would change anything though. THe windows being open makes your car battle the wind more just going straight.
Nite-Mare is offline   Reply With Quote
Old 05-08-2006, 08:04 AM   #7
In a v6, the a/c compressor pulls so much that it makes a pretty big difference. At least this is what I've observed.
Old 05-08-2006, 08:05 AM   #8
Nite-Mare's Avatar
oh. Plus I have O/D pulleys...
Old 05-08-2006, 08:07 AM   #9
You mean underdrive pulleys lol.
But yeh, the 4.6 has enough power in the rotating mass that it can turn the a/c compressor with minimal parasitic loss in comparison with the v6.
Old 05-08-2006, 08:44 AM   #10
underdrive pulleys, exhasut, cold air intake, and a tune can all help gas milage IF You drive the car good and get them to tune the car under non wide open throttle conditions (may take some data logging on your part to get it set right and it will take a VERY good tuner)
Old 05-08-2006, 09:02 AM   #11
Nite-Mare's Avatar
Oops! lol.
Good info.
Old 05-09-2006, 06:53 PM   #12
thanks for the tips guys I think ill start by replacing the spark plugs.. unfortunately I dont think I have the required tools for the job
what would a good price for a tuneup like this be, ballpark?
Old 05-09-2006, 08:59 PM   #13
Replacing spark plugs is one of the easiest things you can do. All you need is a spark plug socket/wrench. Pull the wire off the end, put the socket on the plug, and take it out. Put the new plug in, plug the wire back on, and you're done.
Old 05-09-2006, 09:12 PM   #14
DarkShadow's Avatar
Send a message via AIM to DarkShadow
Most bolt ons actually help gas efficiency. My turbo actually helps highway efficiency, but if I use boost (or if you use the power that comes from the bolt ons) your mileage goes to poopy.
DarkShadow is offline   Reply With Quote
Old 05-10-2006, 08:07 AM   #15
the KEY to spark plugs is taking your time and NOT CROSS THREADING THE PLUGS, using a bit of antiseeze on the threads and tightening them correctly. A ratchet, couple extensions varying in lengths and a spark plug stocket work fine, take one plug wire off remove the plug put a new plug in and put the wire back on. Dont take of all the wires at once or you wont know which order they go in. Check the spark plug gap and set all of them correctly, I am not sure what yours will need to be adn you can not go by the stock ones in the car.
Old 05-13-2006, 12:52 PM   #16
jeffb_211's Avatar
If the gap is the same as a 2000, the gap is .52-.56.
jeffb_211 is offline   Reply With Quote
Old 05-15-2006, 09:36 PM   #17
powerhungry966's Avatar
Send a message via AIM to powerhungry966
i'd say down size your rimz to the 96 fifteens and take your spare and jack out.. uhmm.. rip out ur back seats and replace ur hood and trunk to carbonfiber .. UDP.. less weight better gas! thats my take on it
1989 coupe 5.0 yeessur.
"Shake n bake"
powerhungry966 is offline   Reply With Quote
Old 05-15-2006, 09:53 PM   #18
I get around 28 mpg highway with a full weighted car, including subs and the rest of my crap. Gotta love the 87 mpg tune from justin at vmp. Now if I can just stay off the little right pedal in town...
Old 05-16-2006, 12:19 AM   #19
Aidan_04's Avatar
haha..
some of us seem to have issues with that little right pedal.
2004 redfire 4.6L GT / 1994 rio red v6 vert / 1990 7UP LX vert
2804
^^^my fave V8 chick ^^^
Old 05-16-2006, 05:14 AM   #20
Danger Dude's Avatar
Originally Posted by Aidan_04
haha..
You write any smaller and some of old guys will have to break out the bifocals BY GOD
Old 05-16-2006, 07:38 AM   #21
I need to get a tune, but I need pulleys and a cai first, anyone care to give me say... 1500 bucks for good measure.
Old 05-16-2006, 08:16 AM   #22
you need 1500 bucks just for that?
1999 3.8 V6 Electric Green Mustang
5 speed
Mods: MAC Dual Catback Exhaust, MAC Shorty Headers, CAI, Sequential Taillights, 03 17" Cobra Rims
My Garage
electricstang is offline   Reply With Quote
Old 05-16-2006, 08:38 AM   #23
for GOOD measure lol
Old 05-16-2006, 09:33 AM   #24
lol... in case you have to do each of them twice?
5 speed
My Garage
Old 05-16-2006, 10:36 AM   #25
The 03-04 Cobra's around here who tune at Amazon are using the Metco pulley's and Metco CAI it does not have a bend which seems to be a problem with the 03-04 MAF
Old 05-16-2006, 11:48 AM   #26
Aidan_04's Avatar
LOL, how big do I need to write for ya brother Corey? Can ya see me now?
2804
Old 05-16-2006, 11:59 AM   #27
I will probably go with a jlt cai but I want a tune done with it to make sure im not running lean
Old 05-16-2006, 01:43 PM   #28
YOU NEED TO CHECK OUT METCO!!!!! What you end up buying is up to you but they are having very good success and several 03/04 Cobra's in the UMC club are at 460hp+ and have not gotten into the engine at all. All bolt ons and a Amazon tune
Old 05-16-2006, 02:37 PM   #29
Im going to go billitflow they are EXTREMLY nice.... and color matched to my car lol. I wont be doing it anytime soon, Im looking for a job which I am not ever going to find by the looks of it.
Old 05-16-2006, 07:13 PM   #30
You need to relize, the guy is ancient.
Old 05-16-2006, 10:23 PM   #31
But do you realize you can spell with didley!!!!
Old 05-16-2006, 10:28 PM   #32
I can read her posts just fine....i think you're just old
Old 05-16-2006, 10:54 PM   #33
Aidan_04's Avatar
oh, I know he is.. but I don't fault him for it..
it's okay Brother Corey... we love you anyway.
2804
Old 05-17-2006, 07:08 AM   #34
Im just curious as to how you bought an extremely nice cobra without even a job in line.
5 speed
My Garage
Old 05-17-2006, 07:59 AM   #35
bbunt302's Avatar
He sells a lot of drugs around here. He's probably one of the biggest coke dealers in the Southeast.
Scary stuff.
Fuel Efficiency NotoriousSPG Pre-2005 V6 Mustang 11 06-10-2008 07:49 AM
Efficiency over aesthetics (sound) eddied Pre-2005 V6 Mustang 7 09-22-2006 06:23 AM
11:57 PM
