Changing the fuel filter - Mustang Evolution
Old 05-08-2006, 08:27 AM   #1
I have a 99 v6 mustang and I need to change the fuel filter. I am pretty sure I know what Im doing, but I have a couple questions. Does my car require the special tool? Where exactly is the filter located (I think its close to the gas tank, but havent really looked)? And do I have to press that button in my trunk before hand? Thanks
1999 3.8 V6 Electric Green Mustang
5 speed
Mods: MAC Dual Catback Exhaust, MAC Shorty Headers, CAI, Sequential Taillights, 03 17" Cobra Rims
My Garage
electricstang is offline   Reply With Quote
Old 05-08-2006, 08:42 AM   #2
Re: Changing the fuel filter
you need a special little tool to remove the line, the filter is behind the gas tank, you cant miss it. Just use the tool, remove the lines, and put the new one back in securly. Start the car and check for leaks (you can turn the car to the on position with out cranking a few times to get the pressure built up in the lines as well)
Gas WILL come out when you remove the filter so be ready for it.
Old 05-08-2006, 09:01 AM   #3
Yeh, my car is overdue for this, just gotta get off my lazy butt and go get a tool. As far as the location, it's hard to miss. Just follow your fuel line from the gas tank and you'll run right into it. You need a flat head screwdriver to remove the little metal piece that holds the filter into place.
Old 05-08-2006, 11:07 AM   #4
So if I go to autozone or wherever to buy this special little tool, what is it called or what does it look like?
5 speed
My Garage
Old 05-08-2006, 11:16 AM   #5
bbunt302's Avatar
A word of warning... you may want to either wear some saftey goggles (the kind that have foam round the lense and "seal" against your face) or just be sure you are out of the way when you disconnect the line.
Last time I did it, I was having a hard time getting it off, which resulted me in not being careful of where my eyes were when I finally did. Gasoline + eyes = ouch.
Here's an example of the tool you need:
Easier to do that than try to describe it.
Scary stuff.
Fuel filter? OHHitsKB Pre-2005 V6 Mustang 9 07-12-2010 11:19 AM
overheating after changing the oil filter adapter 2003stangmachI 1996-2004 Mustang GT 8 10-29-2009 08:26 AM
fuel filter 95blackgt 1979-1995 Mustang GT 5 11-11-2008 10:27 PM
fuel filter help? 01mineralgrey6 1996-2004 Mustang GT 13 08-14-2005 09:39 AM
fuel filter HELP project232 Pre-2005 V6 Mustang 3 04-16-2005 07:54 PM
09:49 PM
