Reverse lights - Mustang Evolution
Old 09-22-2003, 10:16 PM   #1
Reverse lights
So. I was backing up today. And there was a mirror/glass window behind my car and I noticed that my backup lights weren't on. Anyhow. I immediately was thinking maybe it was the switch or the bulbs, but I checked the fuse anyway (fuse #11 on my 02) and sure enough it was open. I replaced it and tried to back up and actually saw the fuse pop (it's dark outside). It was pretty cool. But. My reverse lights still don't work. Anyone ever have a short in their reverse lights? Or know where the most likely cause of this is? I haven't messed with my tranny/lights... ever.
Laser02 is offline   Reply With Quote
Old 09-22-2003, 10:45 PM   #2
tire's Avatar
Send a message via AIM to tire
I haven't had my reverse ones go, but that's what fuses are for. You know how to remedy it though, right?
tire is offline   Reply With Quote
Old 09-23-2003, 07:25 AM   #3
Not really. I replaced the fuse and it still blew. I don't know where to begin trying to track down the short.
Old 09-23-2003, 08:52 AM   #4
Region: Iowa
Send a message via AIM to Horse Send a message via Yahoo to Horse
There's probably a problem with the reverse switch. I took mine to the dealership once for a junk syncro, and when they put it back together they put the switch in wrong or backwards or something. Burned out the fuse AND the switch. Had to get the whole works replaced. If you have a manual, try just sliding the gear shift around in reverse, or pulling it out of and back into reverse to see if you can get them to come on at all.
4.2L , CAI, BBK 65MM throttle body, 30lb injectors, SSM ported intakes, FLEX 1/2" spacer, RPM big valve heads, Comp roller rockers and cam, ASP-underdrive pulley, GT rear swaybar, & Quad Shocks, Full MM Coilover conversion, 17" Grey Torque Thrust wheels, FMS Aluminum driveshaft 8.8 rear w/ 3.73 gears, Tri-Ax Shorthrow shifter & SPEC stage II clutch w/ aluminum flywheel
Horse is offline   Reply With Quote
Old 09-23-2003, 09:08 AM   #5
Or you could just buy bigger fuses lol. I have nothing smaller than 50 amps fuses all the way around on my car.
Old 09-23-2003, 11:42 AM   #6
Send a message via AIM to Rellik Send a message via Yahoo to Rellik
50 amp fuses all the way around?!?! :
Talk about Stupid. :
Rellik is offline   Reply With Quote
Old 09-23-2003, 12:22 PM   #7
Zim
You want to **** me?
Zim's Avatar
hope you dont plan on keeping your electrical system too long... lol
I like toys
Old 10-31-2003, 01:48 AM   #8
Thomas91169's Avatar
lol i heard each 50 amp fuse gives about 5hp and 7ft/lbs of torque.
some guy with a civic told me that........
-Thomas-
Old 10-31-2003, 06:00 AM   #9
Danger Dude's Avatar
at 50 amps you could burn up your entire wiring system before the fuse blew!!!! : :no:
Old 11-02-2003, 12:55 PM   #10
one word.......dumb
1998 Subaru Legacy L Sedan
New Hottness
1999 V6 5-speed
14.6 @ 95 w/ 2.22 60'
Wrecked
stangin99 is offline   Reply With Quote
Old 11-03-2003, 09:07 AM   #11
Yes i know it's stupid. That's why I only had them on for a short time. Leave me alone lol. I was experimenting around. But Laser02, if your car is still under warranty you should be able to carry it to the dealership to see if they can fix it.
reverse damage sonicpony Pre-2005 V6 Mustang 14 04-01-2007 10:12 AM
reverse carlosc Pre-2005 V6 Mustang 12 01-18-2007 10:00 PM
Stop Lights vs. Red Lights bbunt302 The Bar 25 12-11-2005 02:49 PM
Guage lights and ac panel lights steedav6builder Mustang Audio & Video 15 03-11-2005 04:10 PM
FOR SALE: tail lights, head lights, clear corners, tail light covers, dvd, xbox games Zim Mustang Parts for Sale and Wanted 15 12-13-2004 01:45 PM
05:08 PM
