Boost Cooler... - Mustang Evolution
Old 05-08-2006, 07:04 PM   #1
Region: Alaska
Boost Cooler...
Anyone ever known anyone to use the boost cooler (50%water/50%methonal)? I'm looking into instead of an intercooler in line with a Vortech supercharger. Just wanted to hear of any personal esperiences with it.
Sonic Blue is offline   Reply With Quote
Old 05-08-2006, 08:37 PM   #2
DarkShadow's Avatar
Send a message via AIM to DarkShadow
Re: Boost Cooler...
I have heard that they are too expensive for no better than they work. They work well, but most of the time people still run intercoolers in addition to something like meth, or nitrous, or CO2.
DarkShadow is offline   Reply With Quote
Old 05-08-2006, 09:23 PM   #3
Region: Alaska
Re: Boost Cooler...
It says up to 60hp gain on a minimal boost, for $399 the kit comes with everything except the water/methanal. If I go with the cooler I'm looking at around 600 for the intercooler without the piping and only a 40hp gain at most. I'm leaning towards the booster just wanted to see what the community thought. Thanks for the reply.
Old 05-08-2006, 09:33 PM   #4
DarkShadow's Avatar
Re: Boost Cooler...
Hrmm...that's pretty pricey. Like I said most people usually run IC's in addition to that and Co2 or nitrous both work better than methanol. Plus I don't like the idea of having to drill into your manifold for most of those direct injection kits.
I would get a decent IC and then get the cryo2 kit on ebay with the intercooler sprayer for about $250 (I've seen them for that sometimes). Those can be refilled at paintball shops. Nitrous works the best but it's more expensive to get refilled. CO2 is cheap.
Old 05-08-2006, 10:00 PM   #5
Re: Boost Cooler...
MAny people use this instead of an intercooler, im sure it will be effective with low boost.
Old 05-09-2006, 07:28 AM   #6
dark's Avatar
Send a message via AIM to dark Send a message via Yahoo to dark
Re: Boost Cooler...
sounds like rice math to me
but who knows
I don't own a mustang at the moment
dark is offline   Reply With Quote
Old 05-09-2006, 08:02 AM   #7
Re: Boost Cooler...
where did you get that number at? I think its to much for what it does~
Old 05-09-2006, 08:05 AM   #8
DarkShadow's Avatar
Re: Boost Cooler...
Well we all need to know what level of boost you will be running. If it is indeed low boost, I suppose that will work because you wont be using it all the time.
However if you use it as a replacement for an intercooler and plan on running more than about 5psi (when some form of cooling device is needed) you will end up having to refill the tank quite often as you should be using it quite often. This gets expensive, i have not priced methanol, but I'm sure over the first few months you could have paid the extra and just gotten an intercooler that works continuously.
I will still stand by having the intercooler first and using these other devices to add to the performance of the intercooler because of efficiency and dependability, and no "woops I forgot to fill the tank".
Plus if you just spent about $100 more you can get a nitrous based cooling system that works worlds better than anything else.
Just my .02
Old 05-09-2006, 08:07 AM   #9
DarkShadow's Avatar
Re: Boost Cooler...
I agree, I looked into the CO2 system and decided it's almost as much as a nitrous kit. If I ever get the urge, I'll just get the NAWZZ!!!
04 gt hp boost 2k4StANGgt 1996-2004 Mustang GT 9 07-20-2009 11:38 AM
got boost?? SaturnMan8227 Pre-2005 V6 Mustang 8 02-25-2009 12:45 AM
How much boost? USMC Gypsy Pre-2005 V6 Mustang 38 01-21-2009 05:56 PM
A/T Cooler Justin 1979-1995 Mustang GT 10 01-15-2007 10:53 AM
ebay auctions, oil cooler, boost gauge, wheels whipster24 Mustang Parts for Sale and Wanted 2 03-28-2005 07:00 AM
10:24 PM
