Injectors - Mustang Evolution
Old 05-08-2006, 09:11 PM   #1
jeffb_211's Avatar
Injectors
Can anyone help a new guy out? I have a 2000 3.8 V6. I need 2 injectors for it. And if anyone can tell me how hard is it to change them. THANX
jeffb_211 is offline   Reply With Quote
Old 05-08-2006, 09:15 PM   #2
DarkShadow's Avatar
Send a message via AIM to DarkShadow
Re: Injectors
It's actually pretty easy. I would budget about 3 hours tops with a few breaks.
All you have to is disconnect everything from the intake manifold (keep track of what went where), unbolt the manifold, lift up the fuel rail, pop out the bad ones, dab a tiny bit of oil onto the injector o-ring, pop the new ones in, puch the rail back down, bolt the manifold back following tq specs and with a new gasket, replace everything you disconnected.
DarkShadow is offline   Reply With Quote
Old 05-08-2006, 09:18 PM   #3
jeffb_211's Avatar
Re: Injectors
Thnx, do you happen to know what the tq spec is?
Old 05-08-2006, 09:58 PM   #4
Re: Injectors
I have a set of 8 19 lbs injectors.
Old 05-09-2006, 03:08 AM   #5
97Stallion's Avatar
Re: Injectors
well since it's a 2000, you have the new "pencil" type injectors I think. So those are 21# injectors, having two 19's will screw him up.
Living one day at a time!
Old 05-09-2006, 06:31 AM   #6
slvr2000stang's Avatar
Re: Injectors
Yes he needs 21# injectors.
Custom Delk motor now DOA
2003 SVT Lightning #1059 of 4270
2000 Vert 4R70W
Only buy from vendors that test and stand behind their products
slvr2000stang is offline   Reply With Quote
Old 05-09-2006, 06:51 AM   #7
Danger Dude's Avatar
Re: Injectors
Torque for what. The injectors actually just push in and the rail is screwed to the upper intake manifold
Old 05-09-2006, 06:54 AM   #8
Re: Injectors
Upper Intake Manifold if I read correctly.
2000 Vert 4R70W
Old 05-09-2006, 07:01 AM   #9
Re: Injectors
Upper intake what???
Old 05-09-2006, 07:53 AM   #10
DarkShadow's Avatar
Re: Injectors
Upper intake bolt tq specs. I don't remember off the top of my head and most people ignore it but they do have a torque spec that I would recommend following as it is there for a reason apparently.
And yes, he needs 21#'s.
Old 05-09-2006, 07:57 AM   #11
Re: Injectors
I think the upper is like 17ft lbs or less
Old 05-09-2006, 08:55 AM   #12
Re: Injectors
That is about right and before you tighten them you need to apply anti-seize on the bolts. This will help you when torquing and preventing damaging the threads in the lower intake. I have had to install heli-cores in a few intakes for friends. The problem is aluminum intake threads have a tendency to break when stressed. So anti-seize acts a lubricant and makes them easier to get out the next time. Also do not tighten one bolt at a time. keep going in a crossing pattern between bolts in increments until the torque is reached as to not put the bolts in a bind
Old 05-09-2006, 02:19 PM   #13
jeffb_211's Avatar
Re: Injectors
Thanx Everyone who sent messages, that really helped me out. I will find out what the tq spec for the intake is and let you know. And if anyone knows where i can get a good deal on the 21# injectors, please let me know.
Old 05-09-2006, 03:58 PM   #14
Re: Injectors
The injectors are orange one from a 2001 gt, dont know what size they are i guess. I thought they were 19's
Old 05-09-2006, 04:47 PM   #15
Re: Injectors
The Ford service manual say 15-22 Inch pounds
STEVE is right 99-04 GT's came with 19's!!! orange or black is 19's
DAMN I cannot get use to you being STEVE!!!
14# injectors rydog Mustang Parts for Sale and Wanted 7 05-07-2008 05:20 PM
Injectors BigL34461 Pre-2005 V6 Mustang 2 11-10-2007 12:20 PM
#24 or #30 injectors? USMCSS 1996-2004 Mustang GT 2 06-11-2007 08:04 PM
injectors wht2002gt 1996-2004 Mustang GT 15 03-07-2007 05:03 AM
19# injectors...$1 Junior2561 Mustang Parts for Sale and Wanted 0 11-07-2004 06:19 AM
10:34 AM
