2000 mustang 3.8 shaking - Mustang Evolution
Old 03-26-2010, 11:08 AM   #1
this unit shakes to deatgh in neutral and only slightly diminished in gear. have checked all external sources, even replaced damper asm, but no avail. have been told the balance shaft was not used in these in 2000. my question is are they right or idiots.
klwiese2 is offline   Reply With Quote
Old 03-26-2010, 12:31 PM   #2
Re: 2000 mustang 3.8 shaking
I cant remember which way it is but in mid 01 they swapped to an the harmonic balancer to or from an internal balance (cant remember but I think 01 had an external balance, you can tell by the notch in the harmonic balancer vs a previous year where its all round, no notches)
It could be a missfire as well either a plug or the coil pack perhaps
Old 03-26-2010, 09:10 PM   #3
SaturnMan8227's Avatar
Send a message via AIM to SaturnMan8227
The External balancer was from 99-00, some late model 00 Stangs switch to the internal balancer. Here's a pic of an after marker underdrive pully. a 99-00 should have noticable notch in it.
SaturnMan8227 is offline   Reply With Quote
Old 03-29-2010, 01:39 PM   #4
You might check for a loose vacuum line. That can cause a rough idle and shake.
jch_1120 is offline   Reply With Quote
Old 03-29-2010, 02:31 PM   #5
Also, the hole that magically appears in the passenger side manifold makes it do that as well, at least it made mine do that before i took them off.
19Delta is offline   Reply With Quote
Old 03-30-2010, 07:35 AM   #6
yea the v6's are known to have cracked headers due to AC condensation so check for an exhaust leak.
Old 04-11-2010, 01:20 PM   #7
rinfield2004's Avatar
This may seem simple and retarded but......have you checked all your spark plug wires and coil pack? Make sure and verify that all your spark plug wires going to the correct plug and are all your spark plug wires plugged into the correct firing order on the coil pack?
Simple and padantic, but its an issue I ran into when I swapped my coil pack and wires.
rinfield2004 is offline   Reply With Quote
Old 04-11-2010, 03:07 PM   #8
CHILE10_STANG's Avatar
Originally Posted by rinfield2004 View Post
this may seem simple and retarded but......have you checked all your spark plug wires and coil pack? Make sure and verify that all your spark plug wires going to the correct plug and are all your spark plug wires plugged into the correct firing order on the coil pack?
Simple and padantic, but its an issue i ran into when i swapped my coil pack and wires.
true - spark plugs and wires will make it shake if they arent plugged correctly or if they go bad...
IMPOSSIBLE IS NOTHING
2000 MUSTANG V6
2001 MUSTANG GT
2014 MUSTANG GT
CHILE10_STANG is offline   Reply With Quote
2000 mustang
very noticeable shaking/bad accel blackonblack Pre-2005 V6 Mustang 6 04-30-2010 07:35 PM
Shaking McGrail482 Pre-2005 V6 Mustang 4 12-12-2006 02:55 PM
shaking 5.0homustang 1979-1995 Mustang GT 5 04-10-2006 09:28 PM
shaking problem at 60mph timekiller Pre-2005 V6 Mustang 6 03-19-2006 12:48 PM
Shaking above 55mph any ideas? SpectorV Pre-2005 V6 Mustang 11 07-20-2004 09:44 AM
11:05 AM
