Won't start - Mustang Evolution
Old 03-26-2010, 10:27 PM   #1
Won't start
my mom bought a 95 that sat 6mths and won't start> its getting spark, turning over won't crank put new plugs in and they come out wet with gas. I bought actron code reader and when hook it up nothing happens.
32vMach is offline   Reply With Quote
Old 03-26-2010, 10:36 PM   #2
SaturnMan8227's Avatar
Send a message via AIM to SaturnMan8227
Re: Won't start
its cranking but wont start... have you changed the coil pack/distibutor and wires also?
if you hear clicking its a stater issue
SaturnMan8227 is offline   Reply With Quote
Old 03-26-2010, 10:46 PM   #3
Re: Won't start
Or an alternator.
19Delta is offline   Reply With Quote
Old 03-26-2010, 10:52 PM   #4
Re: Won't start
an altenator wont effect start.. just charging of the battery. have tried jump starting car or popping the clutch??
Old 03-27-2010, 01:52 PM   #5
Re: Won't start
Its turning over. I even put new battery on it. check and getting good fire. I just don't understand why the actron code reader does nothing when i hook it up. tested it on another car and it works>
Old 03-27-2010, 06:59 PM   #6
Re: Won't start
Is there anyway to test the PCM. i put new coil pack plugs and wires. tried start it with starting fluid in case gas in tank bad.
Old 03-27-2010, 08:20 PM   #7
67mustang97's Avatar
Region: Vermont
Re: Won't start
Does it have a distributor? Check the firing order, I've seen this problem on a Jag cap was off 180 degrees.
Old 03-27-2010, 10:11 PM   #8
Re: Won't start
No it has coil pack. I have checked EVERY ignition part getting good fire. Removed oil fill cap to see if timing chain broke and the rockers were moving. What throws me is fire to plugs but they are wet when pull them. WHY wouldnt code reader even power on when hooked up. The check engine light stays on, shouldn't it go off after little bit when the key is on but not started?
Old 03-28-2010, 07:18 AM   #9
Region: Vermont
Re: Won't start
Maybe it's a crank position sensor. Not sure I think my check engine light goes out after a few seconds, I'll check. Your sure it's the right firing order?
Old 03-28-2010, 10:01 AM   #10
MonteCitan's Avatar
Re: Won't start
If plugs are wet.. Try holding the gas pedal at WOT position, then crank..
If its getting spark, you have fuel.. This may just work.. I've seen flooded engines still have crank/no start issues after letting them sit for days
If you're getting spark, your computer is likely ok, does the code reader connect at all?
Try disconnecting the MAF sensor and cranking again
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 03-28-2010, 10:10 AM   #11
Blogger
99ford's Avatar
Re: Won't start
Is the scanner meant for OBD I ? I believe 1980-1995.? Also have you checked all gaskets and seals? That may be worth while especially if the car was sitting for a long time.
Old 03-28-2010, 10:14 AM   #12
MonteCitan's Avatar
Re: Won't start
Good call.. though the connectors are different, so he should be able to figure that one..
94-95 3.8s were OBDII
Old 03-28-2010, 03:22 PM   #13
Re: Won't start
Well did compression test. 1=85psi 2=30psi 3=60psi/ 4=80psi 5=60psi 6=115> so far got the intakes off and trying break the dang head bolts. Prbly be better off getting used one to put in it.
Old 03-28-2010, 04:56 PM   #14
Ninethourpm's Avatar
Re: Won't start
cough Ported cough
2000 silver 3.8 5 speed,smoke tint,cold air intake,MAC Long tubes, MAC Catted H,MAC GT catback, SCT Livewire w/ Bamachips tune,
17x8Fr 17x9Rr Bullit Wheels More to come......
96 honda magna vf750, K&N, Vance and Hines pipes Rejetted carbs
Ninethourpm is offline   Reply With Quote
My 99 won't start!! j_worrr 1996-2004 Mustang GT 13 12-28-2009 11:40 AM
where do i start? corey-b25 General Mustang Discussion 2 02-28-2008 09:59 PM
V6 won't start...help stang man Pre-2005 V6 Mustang 2 11-26-2006 01:15 PM
where to start lowflyn Pre-2005 V6 Mustang 4 08-22-2003 05:42 PM
12:21 AM
