Will 99-03 parts fit an 04? - Mustang Evolution
Old 05-17-2006, 01:14 PM   #1
Will this ( 99-03 FORD MUSTANG 3.8L V6 COLD AIR INTAKE W/ FILTER ) cold air intake work on an '04? It's listed for 99-03, but shouldn't it still fit?
Are there even any differences between the 04's and the 99-03's? Or would any part for a 99-03 work for an 04?
Thanks
patersmith is offline   Reply With Quote
Old 05-17-2006, 05:20 PM   #2
Re: Will 99-03 parts fit an 04?
the only differences in the cold air intake between 99 and 04 will be in 01 the placed the intake temp sensor into the MAF so you will need a plug to cut off the air flow since there is no sensor to put in the hole. Thats about it, if you have the sensor located behind the MAF then stick it in the hole, if you dont you best cap it off and the your good.
Cali mustangs have a smog thing in the fender on the side near the air filter and you may have to adjust its position to get the air filter to fit~ if the car is not equiped with this then your fine in that department.
Old 05-17-2006, 06:18 PM   #3
Awesome, thanks for the info SpectorV.
Old 05-17-2006, 10:35 PM   #4
DarkShadow's Avatar
Send a message via AIM to DarkShadow
Unfortunately, the 04's got left out of the loop for lists of what will fit because companies started gearing up for the `05 changes rather than updating their catalogs/lists from `03 to `04.
DarkShadow is offline   Reply With Quote
Old 05-23-2006, 07:12 AM   #5
01-04 is pretty much all the same.
Justin Starkey
2007 Shelby GT500 705RWHP/708RWTQ
2000 Mustang 3.8 A4 TT 450RWHP/475RWTQ 10.996@127 17psi stock 3.8
2006 F250 CC 4x4 6.0L 14.3 @ 93
2006 Mustang 4.0 M5 Vortech 13psi 395RWHP/374RWTQ wife's car
justin00stang is offline   Reply With Quote
Most GT parts fit Cobras? bldgrn83 1996-2004 Mustang GT 6 06-21-2009 12:40 AM
v6 to true exaust. buying parts. am i buying the right parts steveyb927 Pre-2005 V6 Mustang 4 04-16-2009 10:04 PM
will they fit all8280bcc Mustang Wheels & Tires 14 12-26-2006 01:52 AM
Crazy Singe Port Performance Parts/ 94-03 Parts Forged! v6stanger Mustang Parts for Sale and Wanted 4 10-27-2006 12:13 PM
4.2 split port engine parts/torque converter/steeda parts Horse Mustang Parts for Sale and Wanted 33 03-17-2006 04:03 PM
07:21 PM
