FUSE SET UP - Mustang Evolution
Old 05-19-2006, 09:50 PM   #1
Question FUSE SET UP
Does anyone have a 96 mustang ( I dont knwo if the fuse set up is different on years or not..) I believe from what some guys on here have told me my fuse for my cruise control might be what is causing it not to work....well it could be other things but I am gonna check the "little" things first....neway does anyone have the number of the fuse that goes for the cruise control? I dont have an owners manual and I dont want to go spend the $30 bux right now for one when all it could be is the fuse....ne help would be much appreciated...
Debras96stang is offline   Reply With Quote
Old 05-19-2006, 11:09 PM   #2
Justin's Avatar
Send a message via AIM to Justin Send a message via Yahoo to Justin
Re: FUSE SET UP
u could get a hayne manual from a auto store for i think 18 dollars that has all that in it or u could get under the steering wheel and check all the fuses and the ones under the hood and see if any are blown or corroded....might be a good thing ti check anyway to prevent future problems
http://www.mustangevolution.com/forum/signatureuploads/sigpic5474_2.gif
(Project "TORQUE"):burnout:
Mods - Off Road H w/ Flowmaster 40s and 3" x 22" Tips, Shiftkit, Shorties, and 4.10s
Soon to come - UDPs, Off Road X-Pipe, A/T Cooler, and 03' Cobra Rims
Club - Tha Crew Leader of Muscle Car Division
Justin is offline   Reply With Quote
Old 05-19-2006, 11:14 PM   #3
Cajun JungleBoy's Avatar
Send a message via AIM to Cajun JungleBoy Send a message via Yahoo to Cajun JungleBoy
Re: FUSE SET UP
go to pepboys.. if u have one near you, there are usually open manuals not wrapped so you can check up on it.
Cajun JungleBoy is offline   Reply With Quote
Old 05-20-2006, 08:58 AM   #4
Re: FUSE SET UP
its listed in your manual, it has what is where some things share a fuse as well.
Old 05-21-2006, 01:56 AM   #5
Re: FUSE SET UP
went to autozone..looked into a manula and it had jack crap in it for fuses....it didnt even say anything about where or what fuses are what...im lost...i think the fuse box under my dash on my driver side had the fuse ( #15) in it for my cruise control but I want to make sure.....would it be a bad idea to just go ahead and get ALL new fuses?
Old 05-21-2006, 07:27 AM   #6
Zim
You want to **** me?
Zim's Avatar
Re: FUSE SET UP
All new fuses is a little extreme... Ill figure it out for ya hold up.
I like toys
Old 05-21-2006, 07:38 AM   #7
Zim
Zim's Avatar
Re: FUSE SET UP
ok this is out of my manual, should be the exact same though.
Does anything else not work besides your cruise control? Clock maybe?
Heres what the fuse box looks like under there:
Heres the list of what does what:
ID:	13257   Click image for larger version
I like toys
Old 05-21-2006, 07:39 AM   #8
Zim
Zim's Avatar
Re: FUSE SET UP
From that chart, it should be fuse #6
I like toys
Old 05-22-2006, 12:07 AM   #9
Re: FUSE SET UP
THANK YOU SO DARN MUCH ZIM! I looked at my #6 and it was blowed so thank ya very much!
Old 05-22-2006, 12:07 AM   #10
Re: FUSE SET UP
so could that fuse might be why its not working?...oh plus my instrument panel lighting is out on one side...fuse too maybe?
Old 05-22-2006, 12:22 AM   #11
Zim
Zim's Avatar
Re: FUSE SET UP
The fuse is more than likely the problem... lights on your instrument panel (if youre referring to the guages) are just burnt out lights. You can remove the guage cluster and replace those bulbs.
I like toys
Old 05-22-2006, 12:47 PM   #12
Herbstang's Avatar
Re: FUSE SET UP
You earned a cookie Good Info Zim
Old 05-22-2006, 01:53 PM   #13
Zim
Zim's Avatar
Re: FUSE SET UP
im here to help
I like toys
Old 05-22-2006, 02:04 PM   #14
Herbstang's Avatar
Re: FUSE SET UP
Then where's my sig
Old 05-22-2006, 06:04 PM   #15
Zim
Zim's Avatar
Re: FUSE SET UP
Your pictures arent good enough
I like toys
Old 05-23-2006, 06:33 AM   #16
Herbstang's Avatar
Re: FUSE SET UP
p'wned by Zim
Old 05-23-2006, 01:20 PM   #17
Re: FUSE SET UP
ZIM: The gauges for the temperature, fuel and from 60 mph to 0 are out...I dont think I can pull my dash out myself......to confusing
Old 05-23-2006, 01:41 PM   #18
Herbstang's Avatar
Re: FUSE SET UP
Remove the pod bezel then remove the four torx headed screws that hold the dash bezel in place, remove the two wiring harnesses connected to it - then carefully lift the pod out of the dash.
Do a search for mustang pod install you should find one with pictures something like http://www.egauges.com/pdf/AutoMeter/824b.pdf
Old 05-23-2006, 02:18 PM   #19
Zim
Zim's Avatar
Re: FUSE SET UP
its really not hard... if you cant do it take it somewhere that can, it shouldnt be too expensive as it takes about 5 minutes to remove the guages.
I like toys
Old 05-23-2006, 04:14 PM   #20
Re: FUSE SET UP
I just dont wanna do it myself cause my damn *** might tear something up and not be able to put it back right!....I usuallt let the professionals do it....they have more experience than me anyway..
Old 05-23-2006, 04:17 PM   #21
Re: FUSE SET UP
Would I have to remove my steering wheel before I do all this or not?
Old 05-23-2006, 06:16 PM   #22
Herbstang's Avatar
Re: FUSE SET UP
No the only hard part is getting the headlight knob off If you look at the knob you'll see a opening with a metal tab use a bent nail to push the tab down & pull the knob off ,2 screws hold the bezel on remove them and then remove the 4 torx headed holding the gauge pod in pull it out & disconnect the 2 wiring haress connection It's a very straight forward process
Old 05-23-2006, 07:31 PM   #23
Re: FUSE SET UP
could I put red bulbs in there to make my gauges red? or is that like impossible?
Old 05-24-2006, 06:39 AM   #24
Herbstang's Avatar
Re: FUSE SET UP
Might try here AUTO METER Intstrument Gauge Accessories or here Auto Bulbs, Colored Glass Auto Bulbs and LED Auto Bulbs google Search is your friend
Old 05-26-2006, 01:44 PM   #25
Re: FUSE SET UP
ok well I got new fuses put inj there and my cruise control still doesnt work..what could it be?...something expensive to fix I bet!
Old 06-02-2006, 04:23 PM   #26
Zim
Zim's Avatar
Re: FUSE SET UP
Did you check to see if it blew the fuse again? If it did, there may be a short somewhere. I remember I was driving once with my cruise control on, and I turned the a/c on, and it blew the fuse because my a/c clutch assembly and pulley were shorting out the a/c system. The a/c clutch, cruise control, and clock all run on the same fuse...
If its blown now, try replacing the fuse, making sure your heater and a/c are all "OFF" and then see if the cruise control works. If it does, leave the cruise control on, and switch your a/c on and see if that causes your clock and cruise control to go off. If it does, theres a problem in your a/c circuit somewhere and thats whats blowing the fuse. Try that and get back to me.
I like toys
Old 06-04-2006, 01:01 AM   #27
Re: FUSE SET UP
ok tried it but nothing happened..put new fuses in for everything under therr...nothing happened..including the cruise control working...
Old 06-04-2006, 11:17 AM   #28
Zim
Zim's Avatar
Re: FUSE SET UP
Ok so the fuse isnt blowing every time? Has your cruise control ever worked?
I like toys
Window fuse/relay jjpea 1996-2004 Mustang GT 1 03-13-2009 10:15 PM
fuse box? braumab 2005-2010 Mustang GT 5 12-08-2008 03:29 PM
wiring to a fuse Mustangbobby Classic Mustangs 2 08-18-2008 12:48 PM
Fuse problems. Brent Pre-2005 V6 Mustang 6 08-22-2003 01:24 PM
03:38 PM
