P0301 engine code - Mustang Evolution
Old 05-22-2006, 11:09 AM   #1
Exclamation P0301 engine code
I have a 99 v6 mustang and I cant get rid of my check engine light. It reads p0301 "cylinder one misfire". I've replaced plugs, wires, coil pack and both O2 censors!! anybody know how to fix this!?!?!?!
White Stalion is offline   Reply With Quote
Old 05-22-2006, 12:43 PM   #2
Herbstang's Avatar
Re: P0301 engine code
Have a look here OBD-II Trouble Code: P0301 Cylinder 1 One Misfire Detected
Old 09-27-2006, 11:49 AM   #3
This is my theory based on my research.1999-2000 Mustang 3.8L Valve covers allow excess oil to pass into intake manifold through the PCV valve causing excess carbon build up in combustion chambers especially #6 & #3.This leads to pre ignition of 87 octane fuel possibly causing misfire codes.Also engine hesitates and engine rattles when accelerating and climbing.2001 valve cover should reduce the oil intake problem.decarbonize the engine with seafoam or BG 44k and possibly run higher octane should fix the problem.I'm trying this solution first.After I smog my car I'll add an inline oil seperator on the PCV to eliminate oil feedback.Also,I lose about a quart of oil every 500-750 miles.Any Ford techs think this maybe a cause?
EricCartman is offline   Reply With Quote
Old 01-19-2011, 02:39 PM   #4
I have this same issue. Did you ever get an definate answer? Also how do you "decarbonize" an engine?
mightymav72 is offline   Reply With Quote
Old 01-19-2011, 03:05 PM   #5
Injector is the only thing left that you havent checked. Possible. I've seen intake gaskets also cause this. If all else fails, get a compression test done.
Alscobra is offline   Reply With Quote
Old 01-19-2011, 03:25 PM   #6
seafoam (available at autozone and the like) can be used to clean carbon deposits out of the motor. You can put it in oil, vacuum system, and gas etc etc
Old 01-19-2011, 06:52 PM   #7
I've put Sea Foam in the fuel tank, I think I heard you can put it in the brake booster vaccum line to clean the engine, but I'm not sure.
Old 01-19-2011, 08:26 PM   #8
You can also just pour about half a can straight into the oil about 200-250 miles before an oil change. I usually do that every 3 or 4 changes.
19Delta is offline   Reply With Quote
Check engine code- p1443 embecker Pre-2005 V6 Mustang 7 05-12-2014 12:22 AM
check engine light misfire code 98stang460 1996-2004 Mustang GT 6 07-27-2010 08:27 AM
check engine light code help p0102 HELP! slow98gt 1996-2004 Mustang GT 1 05-21-2009 01:52 PM
engine code p0102 and p0113 BigL34461 Pre-2005 V6 Mustang 1 11-01-2006 05:49 PM
10:24 AM
