05-23-2006, 12:07 PM
#1 | | Legacy Member
| Need a torque spec??
going to put on the UD pulley I got from sonic blue, anyone know the spec for the main bolt holding the pulley on?
__________________  Rick Kilpatrick, AAS Automotive Systems Tech, Alamance Community College, Class of 99. 06 5 speed manual Mustang with Pony pkg : GT Mac Mufflers, true duals with one custom pipe. 2.5" system. GT bumper cover, all installed March 7&8 2006. AFE Stage 1 CAI, Motoblue Underdrive pulley, GT aluminum shifter knob, honeycomb rear blackout panel,and dash kit installed. Roush hood scoop and side window louvers installed. SS taillight trim has been installed, new alum. GT steering wheel installed.
05-23-2006, 03:58 PM
#2 | | Terminator Owner
| Re: Need a torque spec??
on my 01 it was 125-130ftlbs, it is very tight and you have to recheck it after a few miles, if its loose you can get cel missfire codes or worse (ruined crank)
__________________ 2003 Cobra Vert (Redfire) #3938 of 5082 @ 05/27/2003
472rwhp/493rwtq - Modification List - Dyno Sheet 2012 Mustang 3.7L M6 (Kona Blue) 2011 Ford Edge Sport (Red Metallic) |
05-23-2006, 04:12 PM
#3 | | Legacy Member
goodentite.
Mine: -03 SB Cobra vert- 2552 of 5082 Born 02/25/03
Our's: 90 7up vert - new project-07 DSG Focus -DD 335 |
05-23-2006, 09:04 PM
#4 | | Legacy Member
I haven't been able to get it much over 70 ft lbs, it keeps turning when I try and torque it tight.
05-23-2006, 09:06 PM
#5 | | Terminator Owner
its gots to be tighter than that. is it in gear.
05-23-2006, 09:12 PM
#6 | | Legacy Member
Heck, I have driven it since then, I thought it was, but I had the handbrake up, it could have been out of gear and I didn't realize it, its that that hard to get to from the bottom, I think I might be able to get the torque wrench on it without taking off a lot of stuff, if I have to remove stuff, its not that bad either.
05-23-2006, 09:13 PM
#7 | | Terminator Owner
I didnt have a problem getting mine tq'ed on my 01 manual.
05-23-2006, 09:20 PM
#8 | | Legacy Member
I remember the GT being a pain, but it was an Automatic too. This being a manual it should be easier, I might not have had it in gear.
05-23-2006, 09:34 PM
#9 | | Legacy Member
Come to think of it, it was turning when I tried breaking the bolt loose with my breaker bar too, I got out the air impact wrench and spun it loose easily.
05-23-2006, 09:38 PM
#10 | | Legacy Member
Put the car in 5th gear, it will be alot harder to turn it then. That's what I did to my friend's gt when I put u/d pulleys on it.
05-23-2006, 09:41 PM
#11 | | Legacy Member
Ohhh, well now, that makes sense, i will try that tomorrow! I wish I knew that correct torque spec, I have a feeling the 4.0L might not be the same as the 3.8L.
05-24-2006, 01:07 PM
#12 | | Legacy Member
Got a torque spec, its only 80ft lbs, I got the torque wrench back on it without taking anything off, and retorqued it to a tad over 80ft lbs, so that should do it guys, its installed, and I can feel some difference in power. I can still turn a bolt or two, even with my messed up back!
06-01-2006, 02:45 PM
#13 | | Registered User
| Re: Need a torque spec?? Quote: |
Originally Posted by Rick0636 I can still turn a bolt or two, even with my messed up back! |
__________________ Originally Posted by Flex:
You are the true cam master dude... |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | |
Similar Threads | | Thread | Thread Starter | Forum | Replies | Last Post | | Torque Spec Transmission pan. | mevanderwiel | Pre-2005 V6 Mustang | 2 | 07-09-2010 08:36 PM | | tokico d spec? | powerhungry966 | Pre-2005 V6 Mustang | 3 | 05-26-2006 03:08 PM | | SPEC-V vs EVO8's | Zim | The Bar | 15 | 06-01-2005 06:27 PM | | 5.0 spec | hate_romania | 1979-1995 Mustang GT | 14 | 08-17-2004 04:37 AM | |
