swap a 98 4.6 into a 95 3.8 - Mustang Evolution
Old 06-04-2006, 04:40 PM   #1
Send a message via AIM to Platinum Stang
I got a complete car for dirt cheap. It a 1998 4.6. Other than just swapping out the v8 stuff such as engine, trans, rear end, shocks, harness, etc. What else is needed. I beleive teh 96 up used a different k member or am i wrong. any information would be appreciated. Money and time are not issues. I just think it would be a fun winter project this year, and I would like to get it done right. Also woudl i need to change the anything else other than the engine harness or would i need to change the dash etc. to get all the correct harnesses to fit. thanks in advance.
Platinum Stang is offline   Reply With Quote
Old 06-04-2006, 04:43 PM   #2
Re: swap a 98 4.6 into a 95 3.8
There's a guy on here who recently swapped a 4.6 into a v6, you should check that thread. His names is wrecked2001 or something like that.
Old 06-04-2006, 06:09 PM   #3
thanx
Old 06-04-2006, 06:34 PM   #4
yea I got this low mileage complete car for 1k. nto a bad deal in my mind.
Old 06-05-2006, 09:05 PM   #5
Region: Hawaii
Things you need
Engine
rear end
transmission
drive shaft
98 k-member
transmission mounts/ might need to be frabricated?
EEC
harness
Instrument cluster
4.6 fuel system down to the fuel tank.
hydrobooster
steering rack/and PS lines
4.6 radiator and fan
Thats all i could think of.
If the 4.6 has an ABS master cylinder and 3.8 does not, a custom brake has to be made to make it work, or you can swap the whole ABS system.
I hope this helps.
99 Atlantic Blue V6- SOHC 4.6 swap, Tremec 3650, 8.8 rear end/ Flowtech Ceramic LT headers, off-road x-pipe, Spintech side exit exhaust. K&N drop in filter, removed snorkel, 18x10, 18x9, Anthracite Bullitt Replicas 295-35's, 265-35's. Eibach Pro-Kit springs, M&M Camber Plates
wrecked2001 is offline   Reply With Quote
Old 06-06-2006, 06:58 PM   #6
thanx. I have teh whole car it was a side collision hit. Happens to be a friend of the family so i got it for a steal. It should be a nice winter project. Ill keep yah posted.
v6Stangin95 is offline   Reply With Quote
4.6 swap to a 5.4 b's stang 2005-2010 Mustang GT 9 06-21-2010 10:26 PM
Possible V8 Swap? NeedSomeMods Pre-2005 V6 Mustang 5 05-18-2010 03:43 PM
4.6 - 5.4 swap bruyn 1996-2004 Mustang GT 19 01-21-2010 07:25 AM
5.8 swap ? Z-EATER 1979-1995 Mustang GT 1 05-19-2008 06:29 AM
t5 swap powerhungry966 Pre-2005 V6 Mustang 7 10-19-2005 09:18 PM
11:59 AM
