Problems With My 1995 Base Mustang - Mustang Evolution
Old 04-07-2010, 06:17 AM   #1
I have Ford Mustang 1995 Base I checked it with theOBD2 and gave me all those codes error
P0102
P0123
P0340
P1505
P1643
P1364
P1365
P1731
Can Anyone Help what i can do with it?
MALITOU is offline   Reply With Quote
Old 04-07-2010, 01:05 PM   #2
upton7's Avatar
Re: Problems With My 1995 Base Mustang
What does it do when you drive? Is it just the check engine light that made you check it or is it not running good?
Old 04-07-2010, 09:39 PM   #3
lack of power in engine while u fully stop then try to move with full accelerate it move slowly u don't feel the engine power but about high speed none a problem it close on 180km/hrs and the speed limiter begin working.
Old 04-08-2010, 10:07 AM   #4
upton7's Avatar
Well someone on here wil know the codes and will tell you. Here is my advice tho check to make sure the air filter is clean the fuel filter has been changed in the last 12,000 miles. Maybe check the spark plugs. Basically give it a tune up.
Old 04-08-2010, 07:11 PM   #5
Thumbs up Re: Problems With My 1995 Base Mustang
answer to your question. I also have a 1995 GT they have 2 OBD1 and OBDII connectors in the car confusing to say the least. If you look near the heater core/ac next to the roght fender you will see the OBD 1 connector use that instead of the OBDII connetor i had the same problem with the codes. A mechanic friend told me about it never had problems with the codes since. GOOD LUCK
lilwop44 is offline   Reply With Quote
Looking at a 03 Mustang Base, what should I look for? Tuscloud 1996-2004 Mustang GT 10 08-03-2010 02:14 PM
1995 gts problems bobbygts 1979-1995 Mustang GT 2 08-23-2007 09:46 PM
12:38 AM
