1996 V6 to V8 engine swap. - Mustang Evolution
Old 04-09-2010, 09:51 AM   #1
I just bought a 1996 Mustand with a V6 and I either would like to put a 5.0 or a 351W in the car. What all do I need to get this done? Should I go carb or fuel injection? Just looking for some help here. Any tips would be great! Thanks, Kevin.
deere291 is offline   Reply With Quote
Old 04-09-2010, 10:33 AM   #2
Re: 1996 V6 to V8 engine swap.
Well, with the 5.0 you're probaby going to want a donor car. Then you'll have all the engine components, harnesses, ECU, etc. If the car is a daily driver, I'd stick with FI. If it's a weekend cruiser where you're not concerned about maintenance and mileage, you could carb it.
The 351 windsor would be different. It would take more work and probably some modifications to the engine bay. People have done the swap before so it is possible.
Either way you'll want to upgrade your drivetrain, suspension and brakes if you do swap engines.
Old 04-09-2010, 11:21 AM   #3
In order to put the 5.0 in do you have to change the K-frame? Or do you just use different engine mounts?
1996 v6 swap Kelo Pre-2005 V6 Mustang 0 06-02-2008 09:05 AM
engine swap 1989 to 1992 4 cyl engine dannyc1992 General Mustang Discussion 0 02-08-2008 02:59 PM
what is needed to swap the dual cam v8 mark 8 motor into a mustang gt 1996 MIA1996gt 1996-2004 Mustang GT 1 09-12-2006 10:36 PM
1996 Mustang 3.8 to swap to 1999- 2004 3.8 NewkidonDblock Pre-2005 V6 Mustang 5 05-30-2006 10:17 AM
1996 GT Stang engine swap with.... cagedthought 1996-2004 Mustang GT 12 03-28-2005 09:27 AM
02:34 AM
