Got my V8 sound back but ??? - Mustang Evolution
Old 06-14-2006, 08:12 PM   #1
05STANG's Avatar
Region: Nevada
OK I took someones advice and went strait true duals a few weeks ago and noticed no great difference other than I lost my quiet but V8 sound with that horrible 3 cylinder per bank idle. So an $29.00 later E Bay X pipe take off and $25 to weld it in at my favorite muffler shop and the old sound is back better than ever with a noticeable difference in pickup whew!
BUT This 5 speed automatic is wierd easy on the pedal and shifts are right on and rock solid. Get on it or downshift for power and the computer has a mind of it's own may or may not down shift depending on speed and RPM's or decides to just go down one gear instead of two, what the hey?
Has anyone reprogrammed the auto using either the Xcal or Diablo and was it worth it? did it really make a difference on the basic stock 05 STANG. I know it does if your running boost snf mods but will It really help the auto shift and anything else?
I need some real experience on this not thoughts, thanks.
Name:	New front end 274.jpg
ID:	13473   Click image for larger version
Name:	New front end 174.jpg
Name:	New front end 225.jpg
I COULD HAVE HAD A V8
05STANG is offline   Reply With Quote
Old 06-14-2006, 08:15 PM   #2
Re: Got my V8 sound back but ???
I don't have an 05, but when I put a chip on my auto it was a very very noticeable difference. Fast, crisp shifts. Downshifts almost instantaneously, upshifts a ton faster. If I floor it, it shifts very aggresive, otherwise it just shifts faster than normal.
With the xcal2 you can actually go through and change the firmness of the shifts to how you want them to feel.
Old 06-14-2006, 09:07 PM   #3
05STANG's Avatar
Region: Nevada
Thanks, but I need some specifics on the 05or 06 N/A auto as their are differences from 04 back.
Old 06-14-2006, 09:39 PM   #4
DarkShadow's Avatar
Send a message via AIM to DarkShadow
Principal is the same tho. The X-cals are very good at picking up your auto and I would strongly recommend them for any auto but most certainly a Ford auto regardless of the car.
DarkShadow is offline   Reply With Quote
Old 06-14-2006, 09:52 PM   #5
slvr2000stang's Avatar
The 05 and up really benefit from reprogramming.
Custom Delk motor now DOA
2003 SVT Lightning #1059 of 4270
2000 Vert 4R70W
Only buy from vendors that test and stand behind their products
slvr2000stang is offline   Reply With Quote
Old 06-14-2006, 11:12 PM   #6
Thomas91169's Avatar
its an auto. itll never respond the way you want it to. either have to get used to it, or get a manual car.
-Thomas-
Old 06-14-2006, 11:16 PM   #7
You would be suprised what a good tune will do for it though. I can honestly say my automatic shifts about as perfect as I could ask.
Old 06-14-2006, 11:25 PM   #8
DarkShadow's Avatar
The one thing I would prefer to have a maunal over an auto is the ability to launch at a higher rpm. That's all. A tuned auto is much more comfortable and efficient than a manual IMO. However, a manual can be a little more fun to "play with".
Old 06-15-2006, 08:05 PM   #9
05STANG's Avatar
Region: Nevada
So no one has used the Diablo Sport tuner or Xcal on an 05 or 06?
Old 06-16-2006, 08:13 AM   #10
Get a REAL tune on a dyno from a very good tuner or dont waste your money.
Old 06-16-2006, 01:43 PM   #11
downtime's Avatar
Don't just get one with the factory canned tunes, call Doug over at bamachips.com and get his XCAL2. He does 3 custom tunes on it (I chose 89 performance, 93 performance and 93 torque), and tell him you want the shift points firmed up and the silly throttle-by-wire lag taken out. You will truly be amazed at how much better your car runs and drives. My car shifts hard enough now to chirp the tires while running through the gears. He can tune for any CAI you may have, or for the stock box too.
Come Join The Mineral Gray Mustang Registry, Click here!
See more at 05sixpack.com
C&L CAI;XCAL2;Bamachips 93-Perf Tune;True Duals w/x-pipe
GT Bullits;GT Scoop;12" LeMans Stripes;SS Side Louvers
downtime is offline   Reply With Quote
Old 06-21-2006, 12:05 PM   #12
Rick0636's Avatar
I have had chips and shift kits, don't know if there is a shift kit available for the new five speed auto or not, but if there is, go with it, not that much, and a whole world of difference.
Old 03-07-2007, 10:40 PM   #13
sinspawn7's Avatar
(my cars an auto) i use the diablo tuner i'm runnin the standard performace tune untill i can get it on a dyno. im happy with it so far i can feel that added kick when it shifts gears.
sinspawn7 is offline   Reply With Quote
how does this sound? ryanxstang Pre-2005 V6 Mustang 0 08-09-2008 11:42 AM
More sound!! mustanggt4390 1996-2004 Mustang GT 14 11-20-2006 03:35 PM
how (if it could) make my auto sound to a manual sound MaKaVeLi 1996-2004 Mustang GT 18 10-18-2006 09:56 AM
how would this sound? a00v6stang Pre-2005 V6 Mustang 7 02-16-2006 09:08 PM
sound of an s/c oaktonarcher Pre-2005 V6 Mustang 14 04-09-2005 11:16 AM
06:54 PM
