99-04 bullit wheels to 05-09 ? - Mustang Evolution
Old 04-11-2010, 02:39 PM   #1
CHILE10_STANG's Avatar
Whaaaats up? Hoping someone can help on this...
I currently have a 2000 v6 with deep dish black bullits (18x9 front 18x10 rear) and i want to get an 05-09 gt. I want to know if i can swap these bad boys to the 05-09 mustang?
Thanks! :d
IMPOSSIBLE IS NOTHING
2000 MUSTANG V6
2001 MUSTANG GT
2014 MUSTANG GT
CHILE10_STANG is offline   Reply With Quote
Old 04-11-2010, 02:42 PM   #2
Jordan's Avatar
Re: 99-04 bullit wheels to 05-09 ?
i dont see why not. as long as the lug nut holes line up you should be good. i got my rims from a buddy who had them on his older 5.0 and we threw them on and i havent had a problem.
Red 1998 Mustang V6 5-Speed. Flowmaster True Dual Glasspack Exhaust, AM Cold Air Intake, Black Chrome Cobra 17x9 fronts, 17x10.5 rears, short throw shifter, rear bumper inserts, billet grill top and bottom with pony insert, chrome shorty antenna, chrome shift knob, halo headlights-HID's 8000k, smoked fog lights-HID's 8000k, custom radio and speakers, Eibach Pro-Kit lowering springs
Jordan is offline   Reply With Quote
Old 04-12-2010, 09:44 AM   #3
Thanks! :d
they will fit, however they will stick out further than on your car. i believe it was hottcobra that did the same and they stuck out a little past the fenderwell from what i remember. not sure what size rims he had.
tigerfan2771 is offline   Reply With Quote
Old 04-12-2010, 09:52 AM   #4
Yah, just check offset and backspacing on your bullitts, they should fit on the +05s. I've seen quite a few with 94-04 wheels before. They might stick out though being wider than stock 94-04 wheels such as 17x8's.
94-04 18x9" bullitt: backspacing: 5.94" offset: 24mm
05-09 18x9" bullitt: backspacing: 6.3" offset: 34mm
94-04 18x10" bullitt: backspacing: 6.3" offset: 22mm
05-09 18x10" bullitt: backspacing: 7.2" offset: 45mm
Bolt pattern is 5x4.5" for both styles.
These are based off American Muscle's wheels, iirc you bought yours through them.
Old 04-12-2010, 09:55 AM   #5
They will stick out more, but not much. My friend has my 03 cobra rims on his 08 GT and they look fine, they probably stick out .3-.4 inches to much but overall the rears do not stick out from under the fender lip an the fronts barley do (but he is lowered and this effects it a little).
Remember though tires are different, so if you run the tire on a 94-04 vs 05+ you have to calibrate it to work as the 05+ have a taller tire normally.
Old 04-12-2010, 09:58 AM   #6
+1
Black Bullit Motorsport Wheels (AM.Com) CrzyBeautiful Mustang Wheels & Tires 10 10-30-2009 07:17 AM
bullit wheels sonicpony Mustang Wheels & Tires 16 04-02-2008 06:58 PM
17x8 bullit wheels/tires chargedpony Mustang Parts for Sale and Wanted 3 04-03-2007 06:16 AM
bullit wheels and tires STEVE Mustang Wheels & Tires 15 06-25-2004 11:18 AM
Bullit Wheels cypress The Bar 3 12-21-2003 06:36 PM
01:22 PM
