Handy cam chart (for experts) - Mustang Evolution
Old 06-18-2006, 11:57 AM   #1
RGR
Send a message via AIM to RGR
Overlap Estimator: Section 1 is for street towing, 2 is for regular street,
3 is street performance, 4 is for street/strip, 5 is for race, and 6 is Pro race.
To make the most of this chart, you will need to take into account where, in terms of valve size per cube, your engine falls. For, say, a 3.8 engine with decent-sized valves (SPI), the overlap selected needs to be toward the short end (left side) of the segment that fits your application. For Single Port, add some LCA if you are running stock valves. If it's a typical 4.2, then choose something around the middle of the relevant segment. If the engine in question is a big-block or a really big-inch small-block (both of which are typically under-valved), then select the overlap toward the larger, righthand side of the relevant segment.
USE OVERLAP @ ADVERTISED DURATIONS ONLY!
Line A is for 3.8 engines, B is for strokers and line C would be really huge strokers,
(no real applications for the V6 crowd yet).
As you will notice the chart overlaps somewhat, a cam in category 1 on
line B (4.2 truck cam, street towing) @ 30* O/L would make a decent
"regular street" 3.8 cam also at 30* O/L. Chew this over a while and then
I'll lay a formula on you guys later, that generates full duration specs from the
the info off the chart we're using here!
Originally Posted by Flex:
You are the true cam master dude...
RGR is offline   Reply With Quote
Check out This Handy Dandy Shift Knob bluemustang The Bar 7 05-06-2007 11:42 PM
Pork and Coke? Who has some handy PureVenom Pictures and Videos 11 03-10-2007 03:09 AM
Flow chart FTW n8r Pictures and Videos 9 03-01-2007 03:42 AM
Great pie chart! n8r Pictures and Videos 15 02-26-2007 04:58 PM
05:59 PM
