eec fuse blown ? car dead - Mustang Evolution
Old 06-20-2006, 10:45 AM   #1
Hello and please help.
1996 V-6 auto.
Recently I had a rebuilt engine installed. a few months later the car dies while driving,.. actually it was snowing ,I have two kids that wanted dad to do a doughnut in the snow,.. I did,.. smelled burnt wires then a few blocks later it dies. checking the engine compartment fuse block, I found the fuse for eec is blown. Changed the fuse and it blows imediately when the key is turned on. But,.. not knowing much at all about computers in cars,... I do not know where to go from here.
kskatz is offline   Reply With Quote
Old 06-20-2006, 11:14 AM   #2
Re: eec fuse blown ? car dead
Not much of an electronics geek as some guys around here, but maybe you have a bad ground wire? I don't know. Either way, welcome to the site, I am sure someone who knows more about these things will set you strait.
Old 06-20-2006, 11:15 AM   #3
sounds like there is a short in the system blowing that fuse everytime power is put to it. I would try to trace the wires and see if you can find where the damage is and repair it. It may be a job for a shop to look at. See if you can find the problem via the engine bay and looking under the dash. Follow your nose if you can still smell the burning wires.
Old 06-20-2006, 11:16 AM   #4
There is a fuse panel in the engine bay behind the battery and under the drivers side dash near to the door.
Old 06-20-2006, 11:38 AM   #5
Ya, I found the one in the engine bay, that's where the fuse for the eec is.
Do you nkow where the eec component is?
Old 06-20-2006, 11:51 AM   #6
Herbstang's Avatar
Welcome
you will need to look under the passenger side kick panel Click image for larger version
Old 06-20-2006, 12:06 PM   #7
Thank you very much, I appreciate the time your taking to help me.
Old 06-20-2006, 12:26 PM   #8
Herbstang's Avatar
Not a problem !! That's what ME is all about
Old 06-20-2006, 01:35 PM   #9
slvr2000stang's Avatar
Follow the harness from the fuse box to the EEC.
Look for any signs of any wires rubbing or burnt.
Custom Delk motor now DOA
2003 SVT Lightning #1059 of 4270
2000 Vert 4R70W
Only buy from vendors that test and stand behind their products
slvr2000stang is offline   Reply With Quote
Old 02-27-2009, 03:27 PM   #10
i have the same problem but no wires got bruned that i no of. people told me the ecm was bad so i replased it and it still blowing the fuse
pcoates23 is offline   Reply With Quote
Old 02-28-2009, 07:50 AM   #11
It does kinda sound like something is shorting out somewhere. I'd check the grommet where the ECU wires come through the firewall, in cars that are starting to age you're bound to tear up a grommet and cut a wire at some point.
This just in... Dan Akroyd dead in car crash Zim The Bar 17 01-26-2009 09:38 PM
Need Help: Car throwing EEC-IV Code 224 PureVenom General Mustang Discussion 3 01-04-2009 05:27 PM
EEC wiring for fun Tbird232ci Pictures and Videos 3 09-27-2005 03:16 PM
eec code??? greg_g70 Pre-2005 V6 Mustang 10 08-27-2004 07:28 PM
05:27 PM
