Pulleys! - Mustang Evolution
Old 04-13-2010, 08:17 PM   #1
Pulleys!
hello!
can i put gt pulleys on my v6! I found some pullies on americamuscle.com and i need to know?
thankx
gasteven is offline   Reply With Quote
Old 04-13-2010, 08:26 PM   #2
upton7's Avatar
Re: Pulleys!
Nope you need the ones for the v6.
Old 04-13-2010, 08:37 PM   #3
Re: Pulleys!
I don't believe GT pulleys will work. The v6 specific udp's depend on the year v6, I can't remember which year you have.
The 94-98's require a new crank and water pump pulley which can be had for around $90. BBK makes a popular udp for those years.
For the 99-00 and 01-04's you need a crank pulley and a harmonic balancer for $214-225 depending on where you buy it. ASP makes a good 99+ pulley.
Old 04-13-2010, 08:37 PM   #4
Re: Pulleys!
Nope, just like upton said, you'll have to get the v6 ones.
Ford Mustang 3.8L V6 Performance Parts FREE SHIPPING!
19Delta is offline   Reply With Quote
Old 04-13-2010, 08:39 PM   #5
Re: Pulleys!
Noooooo!!! Not RPM Outlet
I had issues with them back in 06 and I doubt they got their **** together...
Here try this place:
1994-1998 Ford Mustang Underdrive Pulleys at AmericanMuscle.com - Free Shipping!
Old 04-13-2010, 08:41 PM   #6
Re: Pulleys!
go with the asp 25% underdrive crank pulley. i gained a solid 8rwhp across the powerband with 4rwhp at the very peak.
tigerfan2771 is offline   Reply With Quote
Old 04-13-2010, 08:45 PM   #7
Re: Pulleys!
Did you have it dyno tuned after you installed the udp?
Old 04-13-2010, 08:52 PM   #8
Re: Pulleys!
well i did a before and after with just the pulley. then i had it dyno tuned.
Old 04-13-2010, 08:56 PM   #9
Re: Pulleys!
Nice, that helps to confirm that the 25% udp does actually offer some gains. I know that has been a hot topic for discussion..."do udp's really offer any gains?"
Old 04-13-2010, 10:11 PM   #10
Re: Pulleys!
yea i was definately suprised and wouldnt have believed it without seeing the dyno graph
Old 04-14-2010, 07:24 AM   #11
upton7's Avatar
Re: Pulleys!
I can't remember if its the 4.6's or 3.8's but one of them changed the water pump style and they use different pulleys i think its the 4.6 but I'd check and make sure.
Old 04-14-2010, 01:12 PM   #12
blackonblack's Avatar
Re: Pulleys!
over $200 for less than 10 hp. meh. whatever floatsur boat
2004 3.9L v6
Black on black on black
MAC Cold Air Intake, 4.10 gears + T-Lok, SCT Tuner, dual H piped flowmaster super 40's
blackonblack is offline   Reply With Quote
Old 04-14-2010, 01:47 PM   #13
Re: Pulleys!
Its pretty hard to get more than 10 rwhp for 200 bucks
Old 04-14-2010, 02:33 PM   #14
Re: Pulleys!
truth be told
2004 3.9L v6
Old 04-14-2010, 06:07 PM   #15
Re: Pulleys!
Yah the 96-mid 2001 water pump pulley has a wider profile. The mid 2001-2004's are shorter and the belt sits near the front edge of it. There is no exact changover date, so you basically have to look.
Ford did all sorts of things with the 96-04 GT's. The two plants acount for a lot of the differences. The romeo plant engines have an 11 bolt pattern on both sides of the valve covers. The windsor plant engines have 13/14 bolt pattern.
To check you can look at your vin no. The 8th character in the vin determins which style you have, "x" being windsor, and "w" being romeo, or just count your valve cover bolts.
Back to that water pump, as said, they changed it during the 2001 model year. The long style water pump from 96-01 is 87mm. The short style 01-04 is 65mm. It's good to check before you get another water pump so you don't buy the wrong one.
The 4.6L GT engines also have two different flywheels. A 6 or an 8 bolt. The windsor's have 8 bolt and the romeo's have a 6 bolt. Best way is to check your engine code.
This is more common knowledge, but in 01, the GT's were available with 2 transmissions. The TR3650 and the T45. You can check the data sticker on the driver side door jamb to verify which one. A "k" is the TR3650, and "6" is the T45.
2003/2004 GT's and Cobras built after 8/2002 used coarse thread banjo bolts. 1999-2003 GT's built before 8/2002 used fine thread banjo bolts.
Old 04-14-2010, 07:27 PM   #16
Ninethourpm's Avatar
Re: Pulleys!
200 for 10hp would be nice i just spent 1700-1800(lts, H and catback w tuner) and probably only got 10 hp
2000 silver 3.8 5 speed,smoke tint,cold air intake,MAC Long tubes, MAC Catted H,MAC GT catback, SCT Livewire w/ Bamachips tune,
17x8Fr 17x9Rr Bullit Wheels More to come......
96 honda magna vf750, K&N, Vance and Hines pipes Rejetted carbs
Ninethourpm is offline   Reply With Quote
Old 04-15-2010, 11:25 AM   #17
upton7's Avatar
Re: Pulleys!
I thought the date was may?
Pulleys SaturnMan8227 Pre-2005 V6 Mustang 12 01-19-2009 02:18 PM
under pulleys sparkylarue Pre-2005 V6 Mustang 4 03-15-2008 01:07 AM
Under drive pulleys, should I or shouldn't I? microflight 1996-2004 Mustang GT 32 07-30-2007 12:31 AM
UD Pulleys mexor 1979-1995 Mustang GT 5 08-11-2004 06:46 PM
UD Pulleys RedDragonV6 Pre-2005 V6 Mustang 8 02-20-2004 12:29 PM
01:15 PM
