Brake help - Mustang Evolution
Old 06-23-2006, 05:15 PM   #1
mrvMustang's Avatar
Exclamation Brake help
I currently have a 98 mustang V6 with 17x9 SVT 03' Silver Rims w/ Bf Goodrich TA KDW 245 Front /275 Rear with a 1.5 drop, i noticed my stopping power is very poor altough i did swap out all rotors and brake pads (Morse brake pads front)(BBC Green stuff on rear) about 6k miles ago and i still have very hard problems braking in emergency situations and such, i been thinking bout upgrading my calipers to the 30th mustang eddition but they look the same just painted up,
Please let me know which Brake Calipers (brembo, stoptech, Cobra, etc.), Brake Rotors (brembo, stoptech, powerslot, etc), and Brake Pads are best for stopping power.
98 MUSTANG V6 AUTO-MAC FENDER COLD AIR INTAKE-STEEDA 4 BOLT FULLY ADJ CASTER/CAMBER KIT-EIBACH PRO KIT SPRINGS-MAC DUAL EXHAUST KIT-S2K BODY KIT-17"COBRA RIMS-245 BF TA KDW (NT)FRONT-275 BF TA KDW (TT)REAR-BLACK WIDOW WING-BULLIT GAS CAP-DUAL PILAR POD-REVERSE GLOW GAUGES-COBRA R HOOD
mrvMustang is offline   Reply With Quote
Old 06-23-2006, 05:16 PM   #2
Re: Brake help
I'd recommend upgrading to the 13 inch cobra brakes in the front. You should be able to stop like you want then.
Old 06-23-2006, 05:20 PM   #3
mrvMustang's Avatar
Re: Brake help
yeah but wouldnt just upgrading the rotors only make the rotors bigger??? I thought you would have to upgrade the Calipers to make your brakes work better?
would it be more stopping power? say an extra 10% or what?
Old 06-23-2006, 05:21 PM   #4
Re: Brake help
The cobra brake package is rotors and calipers. By moving the braking force to a larger diameter rotor, you are increasing the braking power.
Old 06-23-2006, 07:09 PM   #5
I_luv_HP&trq's Avatar
Send a message via AIM to I_luv_HP&trq Send a message via MSN to I_luv_HP&trq
Re: Brake help
I would bleed the master cylinder and the brake lines before upgrading. It's a lot cheaper then new rotors and brakes... Unless you want to spend money and upgrade anyways that's fine but it may not be the solution.
99 Cobra: flowmasters, 18x9.5 cobra R's, soon to be tuned and geared. daily driver
99 V6:in avatar, Mac Cai, true duals/flowmaster 40's ,UDP, custom tuned, bullitt suspension 18" wheels...taken by mother nature
I_luv_HP&trq is offline   Reply With Quote
Old 06-26-2006, 10:32 PM   #6
Re: Brake help
StangSuspension.com - ford racing front 13inch cobra rotors - for 94-04 mustangs ...
StangSuspension.com - ford racing mach1 front calipers - for 94-04 mustangs ...
Get that, bleed the whole system and call it a day, they are a huge improvment over stock.
Old 06-27-2006, 01:33 AM   #7
97Stallion's Avatar
Re: Brake help
Dude, seriously! Find some some old 99-04 front calipers and swap those on to your car. Your car currently (if they're stock) has steel-cast single piston calipers. The 99-04 calipers are aluminum-cast dual piston. You lose about 16lbs off the front end just by swapping them over. It's a direct swap also. So you can use the exsisting roters and everything. The only thing is you MIGHT have to trim you spindles down maybe 1/8" on each side to make some clearence. Other than that, it's easy as pie. I've done this myself and let me tell you the world of difference it makes. You can usually find a set of calipers for about $100-200 on ebay or on the forums.
Living one day at a time!
Old 06-27-2006, 08:03 AM   #8
Re: Brake help
you can swap over 99-04 v6 or GT calipers, simple bolt on (for the most part you MAY have to grind a spot on the mount to make the caliper clear is very easy to do) or you can spend 350-400 bucks to upgrade to 13 inch rotors and 99+ cobra/bullit/mach 1 caipers.
Old 06-27-2006, 07:03 PM   #9
Region: Iowa
Send a message via AIM to Horse Send a message via Yahoo to Horse
Re: Brake help
I'm with I_luv_HP&trq. You probably got some air in the line at some point. Is the pedal a little squishy?
4.2L , CAI, BBK 65MM throttle body, 30lb injectors, SSM ported intakes, FLEX 1/2" spacer, RPM big valve heads, Comp roller rockers and cam, ASP-underdrive pulley, GT rear swaybar, & Quad Shocks, Full MM Coilover conversion, 17" Grey Torque Thrust wheels, FMS Aluminum driveshaft 8.8 rear w/ 3.73 gears, Tri-Ax Shorthrow shifter & SPEC stage II clutch w/ aluminum flywheel
Horse is offline   Reply With Quote
Old 06-27-2006, 07:18 PM   #10
Danger Dude's Avatar
Re: Brake help
Not just air in the line but also water. Every year a brake system can absorb anywhere from 3% to 5% water from condensation due to heating and cooling of the brakes. So in 4 years you can have up to 20% water. You can check this by how cloudy the fluid it. If it looks like choclate milk or very cloud, time to change the brake fluid. High water content in the brake fluid makes them feel spongy and requires more force on the peddal to get it to stop.
Old 06-27-2006, 10:29 PM   #11
mrvMustang's Avatar
Re: Brake help
so upgrade to stock 99+ or cobra twin or brembo 4 piston?
Speed Concepts - M-2300-B - Brembo 4 Piston Front Brake Caliper Set 94-04 Mustangs/00-04 Focus
whats the difference between em beside price??
Old 06-28-2006, 02:42 PM   #12
Re: Brake help
You dont need the four piston ones.
Old 06-28-2006, 03:30 PM   #13
Re: Brake help
cobra brakes will be more than you will need trust me, its a world of difference. Dont buy drilled/slotted buy regular plane surfaced rotors unless you dont mind replacing them every year or two.. and having the horrid noise when stopping.
Old 06-29-2006, 12:14 PM   #14
Re: Brake help
throwing parts at a problem is a backyard mechanic solution. It doesn't matter what brakes you upgrade to, if your MC isn't functioning properly then your braking power will still be poor.
Old 06-29-2006, 02:04 PM   #15
Re: Brake help
Well he never said his MC was damaged.
Old 06-29-2006, 02:45 PM   #16
Re: Brake help
well poor stopping power and a soft pedal can be caused by a dammaged seal in the MC. But you're right I don't know the whole story and what he's already done as far as maintaining and checking the braking system.
I just wanted to throw out some friendly informative advice to possibley save him some money. I don't like when people have a question and the automatic solution is to replace it. This site is better then that.
I'm not bashing the above said comments in any way because they are potentially correct, but there's more to it then buying new parts.
Old 06-29-2006, 03:28 PM   #17
Re: Brake help
the pre 99 brakes are peices of crap regardless so it may just be the way it is. If it dont work weld more **** to it until it does, thats the great motto of america.
Old 06-30-2006, 12:30 AM   #18
mrvMustang's Avatar
Re: Brake help
thinking i will just go for the cobra brakes cheapest solution while looking good, i would rather them be brembo but dealer cost for a BREMBO 00' COBRA R BIG BRAKE KIT is $965 and i aint got that kinda money
Old 06-30-2006, 12:42 AM   #19
97Stallion's Avatar
Re: Brake help
Don't forget if you get cobra calipers you'll need 13" roters or you won't be able to stop at all.
Old 06-30-2006, 12:44 AM   #20
97Stallion's Avatar
Re: Brake help
eBay Motors: Ford Mustang Front Disc Brakes 99-04 5 Lug Conversion (item 190002048804 end time Jul-02-06 17:38:53 PDT)
Definately the best and cheapest route IMO. These are the same calipers I was talking about in my earlier post.
Old 06-30-2006, 02:22 AM   #21
Re: Brake help
It's hard to diagnos car when you are test driving them, getting in there and checking things is the way to do it. Now on the internet sometimes we assume that the person may do what I would do and check everything thus sometimes its really hard to diagnose someone problem over the internet.
But always check the basic stuff first, check the lines for air, or wear, check the master cylinder.
i need brake help meteorachick Mustang Wheels & Tires 9 01-29-2010 07:54 AM
e-brake help tr4w Pre-2005 V6 Mustang 0 04-07-2008 06:25 AM
e brake? ryanxup Pre-2005 V6 Mustang 12 02-11-2007 02:57 PM
E-Brake steedav6builder Pre-2005 V6 Mustang 8 07-28-2004 08:43 PM
04:46 AM
