Negative Camber Eating my Tires - Mustang Evolution
Old 06-27-2006, 09:10 PM   #1
I was hoping somone could point me in the right direction to get the Camber Adjusted on my 98 Mustang
I installed lowering springs in the Front and Rear of my Car and I noticed today that the insides of both front tires are completely worn out. It's an equal amount of wear on both tires, approx 2 inches
Somone told me I have negative camber and it needs to be fixed pronto
I apologize for my ignorance, I appreciate any input
Thank you
Dean
djmaincheese is offline   Reply With Quote
Old 06-27-2006, 09:21 PM   #2
Re: Negative Camber Eating my Tires
These will fix your problem: StangSuspension.com - Ford Mustang suspension parts and performance. Steeda authorized distributor. Make sure you get the correct year
Note: You only need to make one thread.
Old 06-27-2006, 09:25 PM   #3
Brent
Are they easy to install or should I take it to a pro??
How would I actually measure the degree of Camber
Thank you for your help
Dean
Old 06-27-2006, 09:47 PM   #4
The install involves drilling a new hole in your strut tower and replacing both the top and bottom plates of the caster/camber adjustment plates. It's not too involved if you know basic suspensions and have a drill and some time. The instructions with maximum motorsports products are very detailed. I have the 4 way caster camber plates from maximum motorsports and love them.
Old 06-27-2006, 11:52 PM   #5
Autobadges.com's Avatar
we can get you cc plates too
MM CC plates are great
******Click Banner for more information!******
http://www.mustangevolution.com/forum/signatureuploads/sigpic4116_1.gif
Check out AutoBadges.com's Demo Vehicle!
Autobadges.com is offline   Reply With Quote
Old 06-28-2006, 02:05 AM   #6
Originally Posted by djmaincheese View Post
Brent
Dean
You should be able to install them pretty easy. As far as getting it aligned correctly I would install them and then take your car to get an alignment at an alignment shop.
Old 06-28-2006, 09:09 AM   #7
Zim
You want to **** me?
Zim's Avatar
Brent
Dean
Are you mechanically inclinded? If so, they shouldn't be too bad... but even taking them to a professional shop shouldnt be too expensive. Let me know if you plan to purchase those, I have a discount code that will get the 4 bolt C/C plates from MM (best you can buy) for 166 shipped
I like toys
Old 06-28-2006, 09:15 AM   #8
Thanks for the reply Mike
I am very mechanically inclined so it shouldnt be too much sweat,
I was just concerned about geting it exact.
Once I instal the plates should I just take it to pep boys and get them to adjust the alignment correctly?
Old 06-28-2006, 09:32 AM   #9
Zim
Zim's Avatar
yeah, have them put it on an alignment machine... itll come out perfect
Id suggest NOT pep boys as they tend to be idiots at places like that. Take it to a reputable alignment shop or some place like firestone, a good year store, etc... somewhere that they do alignments all day long and have specific person assigned to that job.
I like toys
Old 06-28-2006, 11:23 AM   #10
I_luv_HP&trq's Avatar
Send a message via AIM to I_luv_HP&trq Send a message via MSN to I_luv_HP&trq
yea take it to a shop that just does alignments. I've just taken classes on steering, suspension, and alignment, and learned there's lot's of guys out there that just set up the car and try to get it in the green but don't really know what they're doing.
I'd have them check thrust angle, SAI. of course since the ride height has changed they'll have to compensate for that and should know how to do that.
99 Cobra: flowmasters, 18x9.5 cobra R's, soon to be tuned and geared. daily driver
99 V6:in avatar, Mac Cai, true duals/flowmaster 40's ,UDP, custom tuned, bullitt suspension 18" wheels...taken by mother nature
I_luv_HP&trq is offline   Reply With Quote
Old 06-28-2006, 11:28 AM   #11
The install is pretty straight forward. If you feel comfortable working on a car on a level of 2 our of 10 on a how hard scale you should be fine.
Old 07-01-2006, 01:11 PM   #12
Yes they come with very detailed intructions, you should be able to do it without a problem if you have tools. Then just take it to an aligment shop and you're set.
New Tires eating gas? a3705872 Mustang Wheels & Tires 2 08-16-2009 07:28 PM
So I was in a cake eating contest rydog Pictures and Videos 20 02-22-2007 03:28 PM
Some chick nearly died after eating nothing but CRISPS for three years. Seph The Bar 12 07-08-2005 09:12 AM
Fired for eating meat? WhiteStang99 The Bar 11 08-05-2004 01:53 PM
so i was eating pop corn Rellik The Bar 4 10-22-2003 01:58 PM
05:09 PM
