Engine Question - Mustang Evolution
Old 04-22-2010, 03:56 PM   #1
Vapiant's Avatar
Engine Question
Ok so, I have been eyeing the 4.2 conversion/split port swap for my mustang since the day I bought her about 4 months ago. (Just waiting for summer to give me the time to do it all) And I have been browsing craigslist and ebay and other such possible engine obtaining sources and noticed a Chevy 4.3 for sale ($600, good price!) but figured I would ask to see it that would also fit in the 98 model I have or if it would be a much larger hassle to swap or just wouldn't fit at all. Any info, suggestions, shopping lists, or tips you guys have are all more than welcome! Yall have been very helpful and entertaining so far and I thank you so!
PS: The write-up for this is definitely going into the V6 mag that im just waiting for enough material to be publishment worthy.
Vapiant is offline   Reply With Quote
Old 04-22-2010, 07:32 PM   #2
Region: Iowa
Send a message via AIM to Horse Send a message via Yahoo to Horse
Re: Engine Question
WAY WAY WAY more work to try to fit a chevy engine in there. The 4.2 and 3.8 use the same block so all the bolts will line up for the transmission. WAY less hassle
4.2L , CAI, BBK 65MM throttle body, 30lb injectors, SSM ported intakes, FLEX 1/2" spacer, RPM big valve heads, Comp roller rockers and cam, ASP-underdrive pulley, GT rear swaybar, & Quad Shocks, Full MM Coilover conversion, 17" Grey Torque Thrust wheels, FMS Aluminum driveshaft 8.8 rear w/ 3.73 gears, Tri-Ax Shorthrow shifter & SPEC stage II clutch w/ aluminum flywheel
Horse is offline   Reply With Quote
Old 04-22-2010, 09:08 PM   #3
Vapiant's Avatar
Re: Engine Question
Awesome! Thank you for that, I will avoid the Chevy engine. Figured I would look into it at least. I see you have done the 4.2 swap, any advice? How long did it take you? Thank you again for your help!
Old 04-22-2010, 11:55 PM   #4
upton7's Avatar
Re: Engine Question
All you gotta do is swap the cranks. But while your in there you should get new bearings and I'm not sure what your compression will be but if its low you can get some pistons to bring it up. Maybe some flat tops. And you should probably go ahead and replace the rings. (you don't have to do that extra stuff but its just a good idea to do it while your in there)
Old 04-24-2010, 02:31 AM   #5
Send a message via AIM to VCS_SSSTANG
Re: Engine Question
Try that and let me know how it goes.
You also need pistons.
VCS_SSSTANG is offline   Reply With Quote
Engine Oil Question drkchocolate07 Pre-2005 V6 Mustang 6 07-17-2008 10:21 AM
question on an engine swap 70MustangFB Classic Mustangs 11 04-06-2008 06:01 AM
Question about an engine n8r 1979-1995 Mustang GT 12 11-29-2006 05:05 PM
Engine Mount Question Checkmate Pre-2005 V6 Mustang 9 09-27-2006 06:56 AM
another engine swap question blk99stang Pre-2005 V6 Mustang 5 02-20-2006 06:19 AM
09:16 AM
