Does this Dyno sheet look a little off to you? - Mustang Evolution
Old 04-22-2010, 07:35 PM   #1
Region: Iowa
Send a message via AIM to Horse Send a message via Yahoo to Horse
Check out the torque curve? I've seen some erratic torque curves but I've never seen an engine lose torque at one RPM range just to jump up higher again later. Any ideas? I got it back from the dyno place after 3 freakin' weeks and 2 days later I get a SES light for Too Rich Bank 1.
This project is really starting to suck, mostly because the dyno place doesn't seem to have a clue what they're doing and there isn't another place for 4 or 5 hrs of driving.
4.2L , CAI, BBK 65MM throttle body, 30lb injectors, SSM ported intakes, FLEX 1/2" spacer, RPM big valve heads, Comp roller rockers and cam, ASP-underdrive pulley, GT rear swaybar, & Quad Shocks, Full MM Coilover conversion, 17" Grey Torque Thrust wheels, FMS Aluminum driveshaft 8.8 rear w/ 3.73 gears, Tri-Ax Shorthrow shifter & SPEC stage II clutch w/ aluminum flywheel
Horse is offline   Reply With Quote
Old 04-23-2010, 10:48 AM   #2
Re: Does this Dyno sheet look a little off to you?
what was the smoothing set to? If you turn that off a dyno looks CRAZY for most cars
Old 04-23-2010, 03:05 PM   #3
It could have been a bit of tire spin here and there too. If it was grabbing, letting go, grabbing, etc it could cause weirdness. Or there could be a missfire going on or other weirdness considering you now have an SES light.
Old 04-23-2010, 03:42 PM   #4
Region: Iowa
Thanks guys, I didn't know that there was a "smoothing" setting. I haven't a clue at all. The only information I have is the sheet I posted. I'm going to try to tackle the Rich code this weekend.
Old 04-23-2010, 05:28 PM   #5
Yeh...it all depends on how they have the dyno set to print. Alot of smoothing and correcting going into the perfect graphs you normally see. If it was dropping off 10tq and back up several times I might worry...but that doesn't look too abnormal.
Old 04-24-2010, 09:02 AM   #6
BIG_K's Avatar
was that on a mustang dyno or a dynojet?
00' Mustang : totaled
06' Mustang : DD
83' AMC Spirit GT: Weekend Warrior
BIG_K is offline   Reply With Quote
Old 04-24-2010, 11:11 PM   #7
Region: Iowa
I think neither. The paperwork I got says "dyno-mite" on it.
Old 04-27-2010, 05:59 PM   #8
James02Mustang's Avatar
If the dyno has problems reading RPM it will give you goofy lines
James02Mustang - V6KR - Stroked/Forged/Blown 4.2L V6
Official Project Site - www.mustangjames.blogspot.com
James02Mustang is offline   Reply With Quote
Old 05-06-2010, 05:16 PM   #9
BIG_K's Avatar
never heard of dynomite. lol only thing i could think of is you might have a plug fouling out or giving out under a load but it would be very noticeable and judging by that sheet it looks like all 6 cylinders are firing fine cuz it would have a sudden drop. lol
06' Mustang : DD
Old 05-06-2010, 06:40 PM   #10
racefan966's Avatar
Region: Idaho
J J is back.
racefan966 is offline   Reply With Quote
auto dyno sheet? blackonblack Pre-2005 V6 Mustang 21 01-15-2010 03:53 PM
easy way to bend sheet metal 90 degrees without special tools? fast64 The Bar 13 05-11-2006 09:22 AM
My dyno sheet 97Stallion Pictures and Videos 2 10-18-2004 08:39 PM
Split-port sheet-metal intake ericstanley Pre-2005 V6 Mustang 1 05-12-2004 04:45 PM
NE DYNO DYNO DAY 11/8 BlueDonkey Regional Mustang Discussion 9 11-13-2003 01:51 PM
03:48 PM
