Intake control runner - Mustang Evolution
Old 04-23-2010, 07:51 PM   #1
Foxone's Avatar
Can someone point me to the location of the intake manifold control runner on a 99' 3.8. Im throwing a code saying that it is stuck open and I have no clue where it is to check it out..
Foxone is offline   Reply With Quote
Old 04-23-2010, 09:52 PM   #2
Foxone's Avatar
Re: Intake control runner
Never mind, found it.
Old 04-24-2010, 09:05 AM   #3
racefan966's Avatar
Region: Idaho
If you need help with running the tests let me know I have Mitchelle 1, I can look this stuff up for you.
racefan966 is offline   Reply With Quote
Old 04-24-2010, 10:17 PM   #4
Foxone's Avatar
I found out theres a small plastic clip on the runner that holds a pushrod, that clip was missing, which lets the pushrod fall out, and leaving the control open, damn clip cost 9 bucks at the dealer, the size of a pencil eraser. All fixed now.
Old 04-25-2010, 12:10 AM   #5
Region: Iowa
Send a message via AIM to Horse Send a message via Yahoo to Horse
IMRC butterflies didn't get added to the 3.8 until '01. I'm a little confused.
4.2L , CAI, BBK 65MM throttle body, 30lb injectors, SSM ported intakes, FLEX 1/2" spacer, RPM big valve heads, Comp roller rockers and cam, ASP-underdrive pulley, GT rear swaybar, & Quad Shocks, Full MM Coilover conversion, 17" Grey Torque Thrust wheels, FMS Aluminum driveshaft 8.8 rear w/ 3.73 gears, Tri-Ax Shorthrow shifter & SPEC stage II clutch w/ aluminum flywheel
Horse is offline   Reply With Quote
Old 04-25-2010, 12:47 AM   #6
Ninethourpm's Avatar
Far as i know 99-00s Dont have IMRCs. ?
2000 silver 3.8 5 speed,smoke tint,cold air intake,MAC Long tubes, MAC Catted H,MAC GT catback, SCT Livewire w/ Bamachips tune,
17x8Fr 17x9Rr Bullit Wheels More to come......
96 honda magna vf750, K&N, Vance and Hines pipes Rejetted carbs
Ninethourpm is offline   Reply With Quote
Old 04-25-2010, 04:52 PM   #7
Yah as far as I know, they used IMRC's starting in 01. That was the cause for the extra 3hp and 5lbs of torque. Your runners should be open all the time...as where the IMRC keeps one air passage open and the other open or closed through a valve plate based on rpm range.
below 3000 = closed
above 3000 = open
Old 05-12-2010, 06:53 PM   #8
Foxone's Avatar
Guys your right, that was a typo from me, its an 04 that had the prob (wifes), I have a 99' just a brain fart.
2012 Ford Mustang GT500 To Get Twin-Turbo 'Road Runner' V-8 a3705872 General Mustang Discussion 2 10-13-2009 12:41 PM
Traction control? braumab General Mustang Discussion 30 12-21-2007 02:50 PM
Chavez in control: MarkuzLS1 The Bar 5 01-31-2007 12:55 PM
07:54 AM
