8.8 axle conversion questions - Mustang Evolution
Old 07-11-2006, 03:12 PM   #1
Region: Iowa
Send a message via AIM to Horse Send a message via Yahoo to Horse
I'm looking into upgrading to a 8.8 rear axle with 3.73 gears.
1. are the 7.5 axles different than the 8.8 ones? I assume they are but I wanted to check.
2. anybody know of any good places to pick up an assembled 8.8 axle. I'm having trouble finding one new or used to fit my make.
3. What are everyone's opinions on the 28 vs the 31 spline axles? I'm thinking the 28 ought to be enough.
4.2L , CAI, BBK 65MM throttle body, 30lb injectors, SSM ported intakes, FLEX 1/2" spacer, RPM big valve heads, Comp roller rockers and cam, ASP-underdrive pulley, GT rear swaybar, & Quad Shocks, Full MM Coilover conversion, 17" Grey Torque Thrust wheels, FMS Aluminum driveshaft 8.8 rear w/ 3.73 gears, Tri-Ax Shorthrow shifter & SPEC stage II clutch w/ aluminum flywheel
Horse is offline   Reply With Quote
Old 07-12-2006, 09:41 AM   #2
slvr2000stang's Avatar
Re: 8.8 axle conversion questions
as long as it's from the same year range they are interchangeable.
Unless you are going to have a power adder the 28 spline is fine.
Custom Delk motor now DOA
2003 SVT Lightning #1059 of 4270
2000 Vert 4R70W
Only buy from vendors that test and stand behind their products
slvr2000stang is offline   Reply With Quote
Old 07-12-2006, 04:30 PM   #3
bbunt302's Avatar
If you have a 99-04, you just need a 99-04 GT 8.8. If you have a 87-95 (possibly even all the way back to 79, but I'm not sure on that), you need an 87-95 8.8. The only reason for this is the length of the axle housings. If you have a 94-95 and get an earlier fox rear-end though, you will need to swap to 94-95 axles.
The 7.5 and 8.8 axles are interchangeable into the rear-ends. For example, Brent bought the 8.8 that came in my 90. When we put it in his car, we just took the axles out of his 7.5 (because they were the correct length and 5-lug) and put them into my old 8.8.
28 spline axles will be plenty until you start launching hard on slicks (less than 1.7 60's). Even then, they may hold up for a good while.
Scary stuff.
Old 07-12-2006, 04:56 PM   #4
Region: Iowa
Yeah, I have a 2000, I forgot that wasn't in my sig anymore.
Also, slvr2000 stang Did I understand you right that the 7.5" axles and the 8.8" axles are interchangable?
and I'm in the process of building a blown 4.2 for the car so are you guy's of the opinion that 31 spline would be a better option?
Old 07-12-2006, 04:58 PM   #5
bbunt302's Avatar
It depends on how you are planning to drive it. If it's going to be going to the strip pretty often and launching on slicks: definitely. If you don't plan on running slicks though, I wouldn't worry about it.
Scary stuff.
Old 07-12-2006, 09:14 PM   #6
Region: Iowa
Mostly I just autocross with it. I'll probably take it to a drag strip once in a while, but not all the time or anything... Thanks
Old 07-13-2006, 10:09 AM   #7
31 spline axles are about $225 or so, the 31 spline differential is the more expensive part.
I have an 8.8 out of an 03 GT, A new 31 spline Tru-trac and 4.10 gears.
All I have to buy is the new axles.
2000 Vert 4R70W
Old 07-13-2006, 10:41 AM   #8
If you are building the rear end, I would say to go ahead and install a 31 spline set up. It will give you room to grow, and you have pieceof mind that you wont break the rear end when racing.
Old 09-08-2007, 11:43 PM   #9
I have a 66 Mustang. I am wandering if I can put a 9 inch rear end on it. Does anyone know what rear ends will work with it. I am also trying to put rear disk brakes. I was thinking a newer mustang would work. People I have talked to have gave me mixed out puts. Some say it won't work.
GTDrayer22 is offline   Reply With Quote
Old 09-09-2007, 08:53 AM   #10
bbunt302's Avatar
Unless you are planning on running some serious power, I would stick with an 8.8" for simplicity. A properly built 8.8" will stand up to a lot.
Scary stuff.
Axle conversion LuminaV2 Pre-2005 V6 Mustang 19 09-30-2009 07:36 PM
99-03 v6 to pushrod v8 conversion questions..anyone help svtlx 1996-2004 Mustang GT 0 02-26-2009 05:20 PM
V6 to V8 Conversion Questions SuperItalian Pre-2005 V6 Mustang 8 06-10-2007 09:23 PM
Gear and axle swap questions. DarkShadow Pre-2005 V6 Mustang 15 09-07-2005 02:18 AM
5.0 TB conversion how to? TheSarge Pre-2005 V6 Mustang 6 02-27-2004 07:03 AM
01:52 AM
