sc m90 swap - Mustang Evolution
Old 04-26-2010, 01:05 PM   #1
sc m90 swap
can someone please be kind enough to tell me of a sight that instructs a m90 supercharger from a supercoupe or could you tell me piece by piece what i would need if i would buy the complete kit on ebay pls help thanks in advance
oh sorry the swap is for a 2000 v6 3.8 mutang
3.8boii is offline   Reply With Quote
Old 04-26-2010, 02:12 PM   #2
Ninethourpm's Avatar
Re: sc m90 swap
Well you would have to convert to a single port setup (head, intake)and you would only gain 20 HP and 90 Tq in the end. Better off geting a procharger or turbo setup or an M112(cobra)
2000 silver 3.8 5 speed,smoke tint,cold air intake,MAC Long tubes, MAC Catted H,MAC GT catback, SCT Livewire w/ Bamachips tune,
17x8Fr 17x9Rr Bullit Wheels More to come......
96 honda magna vf750, K&N, Vance and Hines pipes Rejetted carbs
Ninethourpm is offline   Reply With Quote
Old 04-26-2010, 02:13 PM   #3
Re: sc m90 swap
You need the entire engine pretty much, I wouldnt do it for the little hp/tq gains you end up with.
Many are doing the 2003/2004 Cobra M112 Eaton Supercharger swap onto their V6's and getting 260-300hp or so out of them @ 8-10psi~
The supercoupe motor is forged and such and the regular V6 mustang engine is not, and the supercharger has no cooling~ but its not a bad setup for the price~ www.mysteedperformance.com sells the kits or did sell them~
Old 04-26-2010, 05:25 PM   #4
Re: sc m90 swap
a link to mysteeds site if you want to research that route
Mysteed Performance: Making the Impossible, Possible.
Old 04-27-2010, 02:13 AM   #5
Re: sc m90 swap
Mysteed does take forever to get back to you, though. I've contacted him 5 or 6 times about getting the s/c gasket and bolts and still nothing.
19Delta is offline   Reply With Quote
Old 04-27-2010, 01:21 PM   #6
Send a message via AIM to VCS_SSSTANG
Re: sc m90 swap
If you could really do the labor and get ALL the parts for under 1500$ it might actually be worth the swap. Yes your going down to single port but with all the 10 second single ports, the only 9 second v6 mustang is also a single port.
You would make more power, have a wider power and torque curve, and with full exhaust, tune pulley swap you could have a solid low 13s / high 12s v6 mustang. Which would satisfy most people i'm sure.
VCS_SSSTANG is offline   Reply With Quote
Old 04-27-2010, 01:44 PM   #7
Re: sc m90 swap
He lives like 2 hours from me i think (in GA)
Old 05-03-2010, 06:26 AM   #8
Jordan's Avatar
Re: sc m90 swap
i want a m90. whats the horsepower increase on a stock 3.8?
Red 1998 Mustang V6 5-Speed. Flowmaster True Dual Glasspack Exhaust, AM Cold Air Intake, Black Chrome Cobra 17x9 fronts, 17x10.5 rears, short throw shifter, rear bumper inserts, billet grill top and bottom with pony insert, chrome shorty antenna, chrome shift knob, halo headlights-HID's 8000k, smoked fog lights-HID's 8000k, custom radio and speakers, Eibach Pro-Kit lowering springs
Jordan is offline   Reply With Quote
Old 05-03-2010, 07:41 AM   #9
Re: sc m90 swap
not much, you would probably go fro m150 to 200-220~ its a bad setup. I would go with another setup if you wanted to make good power for the investment.
As said above the mysteedperformance.com kit I think clears the stock hood now~
Old 05-03-2010, 07:47 AM   #10
Re: sc m90 swap
It does clear the stock hood now, which is a good thing. Another 500 bones you can save for something else.
Old 05-03-2010, 01:06 PM   #11
Jordan's Avatar
Re: sc m90 swap
Would the m90 be bolt on? Cause I know you have to change a ton for the m112. And that's a lot of money.
Old 05-03-2010, 01:36 PM   #12
Re: sc m90 swap
its not a bolt on, you need pretty much the entire engine to pull it off.
Old 05-03-2010, 01:42 PM   #13
Re: sc m90 swap
You have to change more for the m90 than you do the m112
Old 05-03-2010, 02:32 PM   #14
Jordan's Avatar
Re: sc m90 swap
Howcome? I dont get it.
Old 05-03-2010, 02:47 PM   #15
Re: sc m90 swap
If you've got split-port heads you do. If you've got single ports heads like yours you shouldn't have to.
Old 05-03-2010, 02:50 PM   #16
Re: sc m90 swap
actualy nevermind you have a single port. but you still get close the the same HP gains with a split port and have more room for improvment.
Old 05-03-2010, 03:59 PM   #17
Jordan's Avatar
Re: sc m90 swap
So it is just a bolt on then? But I'm not worrying about too much more improvement. I'm saving for a cobra. I just wanna have some more horsepower.
Old 05-03-2010, 04:05 PM   #18
Re: sc m90 swap
While it is closer to a "bolt on" style supercharger because it's made for single port, it'll be easier if you can find an engine and pull all the necessary parts. salvaged supercharged tbirds and cougar xr7's are abundant.
Old 05-03-2010, 04:30 PM   #19
Jordan's Avatar
Re: sc m90 swap
what are the parts i would need? Thanks for all the help guys.
Old 05-03-2010, 04:42 PM   #20
Re: sc m90 swap
Basically the entire engine lol. It's easier to just have the entire setup available.
The engine is forged, so that's reason enough to just pull the engine and stick it in. Only problem is that most salvage supercharged 3.8's are high mileage engines...so know what you're looking at.
Old 05-03-2010, 04:44 PM   #21
Jordan's Avatar
Re: sc m90 swap
yea true. i will pay attention to what i look at if i find one.
Old 05-03-2010, 04:48 PM   #22
Jordan's Avatar
Re: sc m90 swap
would it be bad to bolt on a m90 to a stock 3.8?
Old 05-03-2010, 06:23 PM   #23
Re: sc m90 swap
Probably not as long as you have a good tune and dont put too much boost on it. You'll probably have a shorter engine life as well.
Old 05-03-2010, 07:33 PM   #24
Jordan's Avatar
Re: sc m90 swap
Damn. I guess I'll try to find a supercoupe motor.
Old 05-04-2010, 07:20 AM   #25
Re: sc m90 swap
Unless you get an amazing deal on a supercoupe engine you can just build your motor and make more power N/A that with a supercharger on a stock supercoupe engine.
Old 05-04-2010, 09:41 AM   #26
Jordan's Avatar
Re: sc m90 swap
yea but that costs a ton more doesnt it? i just wanna make my motor have a good amount of horsepower for a while til i can buy a cobra.
Old 05-04-2010, 10:17 AM   #27
Re: sc m90 swap
just FYI most people that heavily mod their v6's regret it as they sunk X amount of money into the car and cant get it back out ... well thats modding any car i guess lol
Old 05-04-2010, 02:51 PM   #28
Re: sc m90 swap
You can mod the hell out of a cobra and not get anything back. You'll probably even get less then if you left it stock.
Old 05-04-2010, 04:07 PM   #29
Re: sc m90 swap
He might be able to match peak power, but thats it. He won't match the power under the curve or the torque. And we all know peak power isn't fun.
This is with any car, period. I can sink 15k into a v6 mustang, or a z06 corvette and won't get my money back.
This.
Old 05-05-2010, 10:15 AM   #30
Re: sc m90 swap
Yea, plus the more you mod the more headaches you get... thats just the name of the game. Thats why Bolt ons is all im interested in for my car.
Old 05-05-2010, 04:55 PM   #31
Re: sc m90 swap
Thats all you really need for an 03/04 cobra or any car that came factory boosted. But more times than less if you mod correctly and don't try to cut corners you end up with less headaches and a car that still only requires basic care.
M90? Jordan Pre-2005 V6 Mustang 12 06-27-2010 05:12 PM
96 eaton m90 swap 96mustang21 Pre-2005 V6 Mustang 16 03-10-2010 11:07 AM
M90 on a 04 V6 stang Big Nick Pre-2005 V6 Mustang 25 08-12-2008 08:17 AM
what rebuilding to do to used m90 tire Pre-2005 V6 Mustang 4 03-26-2004 11:20 AM
12:31 PM
