? about clutches - Mustang Evolution
Old 07-17-2006, 11:17 AM   #1
? about clutches
From what Ive been told I have about 75% wear on my clutch. Is it dangerous to be driving that way? I have a 3.8L, hopefully one day soon to be a 4.2 so should I upgrade to a preformance clutch? Would I have to get a new flywheel with that? What would an upgrade do? How much would it cost? Where would I look for them?
HotRod.riguez is offline   Reply With Quote
Old 07-17-2006, 12:41 PM   #2
Re: ? about clutches
If its not broke dont fix it. Save up now so when it does go out and start slipping you can have it replaced. I would go back with the stock clutch unless you plan on pushing over 300rwhp or you have a pre 99 mustang. The stock clutch allows you to feather the clutch. If you go with a stiff aftermarket clutch you will lose most of that ability (depending on brand and level of course some are great) and the stock clutch is VERY cheap.
Old 07-17-2006, 03:53 PM   #3
If the clutch slips replace it, I would go with a spec stage 2. From www.stangsuspension.com
Just resurface your flywheel before the install.
Also make sure to get an aftermarket clutch quadrant and firewall adjuster and a new ford throw out bearing.
Old 07-17-2006, 06:45 PM   #4
if you dont plan on having a ton of power a stage 1 will be fine.
8.8 tracklok clutches ringpinion.biz Mustang Parts for Sale and Wanted 1 08-03-2006 01:45 PM
performance clutches oaktonarcher Pre-2005 V6 Mustang 21 08-29-2004 01:46 PM
Clutches! FloMasta24 Pre-2005 V6 Mustang 10 08-14-2004 01:39 PM
clutches STEVE Pre-2005 V6 Mustang 23 07-04-2004 08:52 AM
Why Mustang clutches > Firebird Clutches Rellik The Bar 4 03-03-2004 11:48 PM
04:50 PM
