running problem less power - Mustang Evolution
Old 07-18-2006, 06:04 PM   #1
I have a 2000 v6 running 5 psi procharger s/c, my car has been running rough lately it idles fine my boost gauge hasnt changed readings at any time including when in vacuum. i just seem to have less power. i changed my spark plugs and my wires are good. i have been smelling my exhaust system lately like sulfur smeel of cats.i do still have stock exhaust,and sometimes it takes a little while for my engine to rev down to idle it will stay around 2000 3000 rpm for a few seconds when i stop i have a manual trans. so today i ran a compression check and cyl 1,2,3,4 have around 200psi i think thats kinda high possibly due to carbon buildup from cats starting to get clogged, cyl 5 has 175 and cyl 6 has 125 psi which i think is kinda low. not sure where to go from here. i usually run a 14.2 at the track and this weekend ran a 15.1 getting full boost but my power seemed to drop off in third and 4th gear when going down the track. any ideas would be helpful, im thinking cats and fuel pump i have the fuel pump and wondering i might be getting weak fuel pressure.
jedwards242000 is offline   Reply With Quote
Old 07-18-2006, 07:31 PM   #2
Re: running problem less power
I would check your cats, they may very well be cloged.
Old 07-18-2006, 09:13 PM   #3
DarkShadow's Avatar
Send a message via AIM to DarkShadow
Maybe a fuel pump or weak injector....?
I would definately check the cats first though.
DarkShadow is offline   Reply With Quote
Old 07-19-2006, 04:26 PM   #4
well i checked cyl 6 again today dry it was 115 wet it was 118 so its definitely valve related so i either have a burned valve or carbon build up on the valve is not allowing it to seal properly. so the dual exhaust is on the way and im getting money together so i can take the head off and take a look at my valves but im gonna wait til i get all the parts before i do that.
Old 07-23-2006, 09:20 PM   #5
Probably smoked a piston #6 has a bad habit about running lean .The only way I know to guard against that is have the injectors cleaned and flowed
and put the highest flowing injectors in #3 and #6.
487.4 RWHP 464.8 RWTQ
11.584@124.58
Sponsored by
http://www.Delkperformance.com/
WWW.SUPERSIXMOTORSPORTS.COM
http://www.v6challenge.com
GT-Eater is offline   Reply With Quote
Old 07-24-2006, 08:25 AM   #6
Cajun JungleBoy's Avatar
Send a message via AIM to Cajun JungleBoy Send a message via Yahoo to Cajun JungleBoy
seafoam it.... that'll clean the engine out greatly
Cajun JungleBoy is offline   Reply With Quote
Old 07-31-2006, 11:07 PM   #7
well i highly doubt the piston went up if that happened i would hear it and the compression would be really low not 125, also if the rings were messed up a wet compression test would have brought it up some. if im wrong please explain to me why im wrong but that is my understanding of how that works
Old 08-01-2006, 03:23 PM   #8
KyleUSAF's Avatar
Send a message via AIM to KyleUSAF Send a message via MSN to KyleUSAF
wow..on a boosted car the dual exhaust should help lots..not for that problem but..
Originally Posted by Darkshadow
I could say nothing for my complete awe. He then. confidantly, purchased the gallon.
KyleUSAF is offline   Reply With Quote
Power window and lock problem need help blzfan1963 Pre-2005 V6 Mustang 3 08-08-2008 06:35 AM
power window problem HELP !!!!! wvstang5.0ho General Mustang Discussion 7 07-08-2008 08:56 PM
Running power around the factory amp to the speakers Kiljosh Mustang Audio & Video 0 01-06-2007 09:17 PM
Running the power wire cterie Mustang Audio & Video 10 11-09-2005 02:05 PM
any problem with running this new lower? tire Pre-2005 V6 Mustang 2 02-10-2004 09:17 PM
03:20 PM
