gains from porting - Mustang Evolution
Old 10-03-2003, 11:01 AM   #1
Send a message via AIM to whipster24 Send a message via Yahoo to whipster24
gains from porting
What sort of gains can I get from porting my upper/lower intake and TB?
thanx much
"This year will go down in history. For the first time, a civilized nation has full gun registration. Our streets will be safer, our police more efficient, and the world will follow our lead into the future!"
-Adolf Hitler, 1935
whipster24 is offline   Reply With Quote
Old 10-03-2003, 11:56 AM   #2
Ken
Ken's Avatar
Region: New Hampshire
Of course it depends on the quality of the job. If you do a crappy job you can screw up the TB and your car will run like crap
A good job should allow for maybe a few ponies and a few ft/lbs of torque.. don't expect anything major liek 10rwhp or anything
Can't afford Mods? Go To College!
Ken is offline   Reply With Quote
Old 10-03-2003, 12:49 PM   #3
Monkey's Avatar
you can easily get 10rwhp and 10rwtq.... if you know what youre doing.
but since this is your first time, prolly 3 from the upper and 6 from the lower. the lower is the one you want to focus on. http://www.v6stangs.com/how_to/performance/port_polish/
Old 10-03-2003, 11:28 PM   #4
I figure that I'd just buy an aftermarket TB first, then maybe port the intakes somewhere down the road
-Adolf Hitler, 1935
Old 10-04-2003, 12:22 PM   #5
Rick0636's Avatar
If you don't at least port the crossover as large as the aftermarket tbody, then you will be wasting your money on it. :
Old 10-04-2003, 04:51 PM   #6
Ken
Ken's Avatar
Brandon, Thanks for correcting me. I didn't think porting the intakes was that beneficial
Old 10-04-2003, 05:14 PM   #7
Monkey's Avatar
the upper isnt, but the lower is, especially on single ports. the split port upper flows really well, and the lower flows decently. but the heads are still the most important
Heads ~ 20rwhp
Lower ~ 10rwhp (if ported well)
Upper ~ 5rwhp (if fully ported)
Old 10-05-2003, 09:38 PM   #8
Cool, thanx a lot guys. It's just something I've been thinking of for somewhere down the road. Could you point me to a site that would show how to do the heads?
-Adolf Hitler, 1935
Old 10-05-2003, 09:44 PM   #9
Send a message via AIM to Rellik Send a message via Yahoo to Rellik
what about morana's square porting? #'s on that?
Rellik is offline   Reply With Quote
Old 10-05-2003, 09:47 PM   #10
Its not recommended that you try doing the heads yourself if you have no experince with porting intakes. heads are tricky and need to be done right. If you have some spare heads you can port than that will be the best aay to learn. As for sites I will lok for some.
Old 10-05-2003, 09:54 PM   #11
i HAD some nice ones.
But i reformated and lost my fav list. I will search fo them and post as many i can find.
Old 10-05-2003, 11:08 PM   #12
heres 1.
http://www.sa-motorsports.com/diyport.htm
Old 10-05-2003, 11:19 PM   #13
http://www.corral.net/tech/powerplant/svoheadporting.html
Old 10-08-2003, 07:08 PM   #14
NorwegianMustang's Avatar
Send a message via AIM to NorwegianMustang Send a message via MSN to NorwegianMustang Send a message via Yahoo to NorwegianMustang
What about this site http://www.supersixmotorsports.com
Mods: Magnapacks, BBK X-pipe with cats, BBK CAI, hood struts, KYB Shocks/Struts, Eibach Pro springs, SS Inserts, CDC Light bar, Chrome 17" Bullits with Nitto 555 and N2O with dual purge
NorwegianMustang is offline   Reply With Quote
Old 10-08-2003, 07:16 PM   #15
thats not really a how-to on it. He just sells them.
Old 10-08-2003, 11:13 PM   #16
Granted, none of the links that I tried on that site worked
-Adolf Hitler, 1935
Old 10-30-2003, 09:39 AM   #17
RGR
Send a message via AIM to RGR
I do 1 cylinder on V6 heads for DIY'ers and then they have a pattern to
follow for the rest of it. Substantial savings! It is also marked out for the
port match and everything, I can even rough in all the exhaust ports cuz
of work to the valve guide, it is lots harder than the aluminum.
The savings are around 75% or so, depending on the level of porting.
I can do the same for intakes too. Core charges apply if I supply cores.
For the 94-98 style, it is a bit more cuz I need to do an extra port
(the dogleg center port is different shape) but it is reasonable.
With a cam Monkey's esimated #'s go higher
But he's pretty close. It's possible to get 100 RWHP
total with a complete package if the porting is right.
It also needs a tune and fuel upgrades for sure.
Originally Posted by Flex:
You are the true cam master dude...
RGR is offline   Reply With Quote
Old 10-30-2003, 10:32 AM   #18
Fishers Stang's Avatar
mm I should do that.. how long do you need a car (the stuff to do all that??)
Charles
Old 10-30-2003, 10:34 AM   #19
What would you charge for porting the single cylinder on a set of heads for the 94-98? Please include the core charge. I'm thinking I'd like to have the extra set in case I messed something up ya know.
I was thinking about getting a supercharger in January (tax return) But if I can pick up significant HP with P&P Intakes and heads plus Cam for much less then I might have to go with that!
-Adolf Hitler, 1935
Old 10-30-2003, 10:41 AM   #20
RGR
I usually do it all core exchange, so the install is at your leisure.
whipster, you need to fill out a cam form or at least tell me the
combo you wish to have, then I can tell you what porting you need
and can work up a price. It would be between $125 and $250
probably. I can also do a BV package like that, supplying all
valves and the bowls rough cut for the big valves too, that would
be about $600 for that type package. You finish the porting
Old 10-30-2003, 10:42 AM   #21
hey wipster, how long of a drive is it from Iowa to indiana? we all need to meet up some time
Charles
Old 10-30-2003, 10:45 AM   #22
Danger Dude's Avatar
hey Robert how close are each port in the stock head to being a near perfect match. I was wondering if doing like you said matching to your 1 port being done it would help to do a Volume check with a graduated cylinder to get a measurement of how really close there porting is to yours !!!!!
Just a thought
Old 10-30-2003, 12:09 PM   #23
RGR
I think that just complicates it unnecessarily.
If they (diy'ers) shoot for a cc figure, and
fall short, they would usually remove material
in the easy to access areas, which is not always
the case. That would be worse than a difference
in volume probably. I like to leave most of the
port as cast where it just needs a surface smoothing,
that way the customer can see where the real work
is done and then just cartridge roll finishes the rest.
I make it so the heads are easy to duplicate
Old 10-30-2003, 12:13 PM   #24
OK just over thinking it like most engineering minds do !!!!!
Old 10-30-2003, 12:23 PM   #25
Darn analytical minded engineers.....
...... Oh wait a second
I'm an engineer! eek!!!!!!
-Adolf Hitler, 1935
Old 10-30-2003, 12:31 PM   #26
HAHAHHAHAHAHAHHAHA
Old 10-30-2003, 12:34 PM   #27
RGR
I'm an engineer!
Then you would probably see the logic in using RGR hardware
instead of some other... Talk to any V6 shop on the phone and
then call me
Old 10-30-2003, 12:35 PM   #28
then call me
I believe that I just sent you an email actually
-Adolf Hitler, 1935
Old 10-30-2003, 12:38 PM   #29
cool a tech hook up that might not have happened if Robert was not here !!!!!!
Very glad Robert is here 8)
Old 10-30-2003, 01:05 PM   #30
RGR
thanx DD!
Old 10-30-2003, 04:25 PM   #31
Ahhh yes, I do luv the forums, sure am glad we gots guyz like Robert here
-Adolf Hitler, 1935
Old 11-06-2003, 05:22 PM   #32
Well, I'm looking to become a midwest stangs member soon here so ya should swing by here sometime when we have an event going!
-Adolf Hitler, 1935
Old 11-06-2003, 05:39 PM   #33
Zim
You want to **** me?
Zim's Avatar
id like porting done, but i cant afford it yet
I like toys
Old 11-06-2003, 05:46 PM   #34
RGR
:thumb2: :thumb2: woot!
So glad to be here!
Old 11-06-2003, 05:56 PM   #35
RGR
Kewl, Fish and I are contemplating a Midwest event in Indy (Coltsland)
sct tuner gains edross 1996-2004 Mustang GT 13 09-16-2009 08:53 PM
off road x-pipehp gains? hottcobra 2005-2010 Mustang GT 2 03-06-2009 06:30 PM
HP gains with Tuning? SaferAngel Pre-2005 V6 Mustang 2 09-10-2006 06:28 PM
cam and sct chip tune gains? tedness Pre-2005 V6 Mustang 10 06-01-2005 10:02 AM
stage 1 v6 = what gains? tedness Pre-2005 V6 Mustang 18 02-03-2005 07:46 PM
03:06 AM
