3.8 supercharger off a thunderbird??? - Mustang Evolution
Old 07-26-2006, 09:18 PM   #1
00stang3.8's Avatar
I am a new member and I own a v6. I really want to supercharge it but currently i do not have the money. I recently found a supercharger system off a 92 thunderbird super coupe on ebay for a fraction of the cost of a new system from vortech or something like that. The thunderbird system would suit me fine if its a possibility. Does anyone know if this is possible, or if it would be too much of a pain?? Thanks alot.
00stang3.8 is offline   Reply With Quote
Old 07-26-2006, 09:29 PM   #2
Re: 3.8 supercharger off a thunderbird???
It would be way too much of a pain. It would not end up being any cheaper than buying a Vortec or equivalent Supercharger
Old 07-26-2006, 09:31 PM   #3
00stang3.8's Avatar
really? im suprised to hear that......thanks tho
Old 07-26-2006, 09:51 PM   #4
It would be cheaper to just buy the complete T/C engine and computer and put it in your stang. I also believe you would have to change your whole fuel system from a returnless type system to a return type of the single ports.
Old 07-27-2006, 02:56 PM   #5
00stang3.8's Avatar
alright, yeah that is alot more work than i was planning on.
Old 07-27-2006, 06:00 PM   #6
Region: Iowa
Send a message via AIM to Horse Send a message via Yahoo to Horse
Furthermore, the ports on the SC super charger don't line up with your split port heads or split port lower intake. There'd need to be some kind of adapter plate to make that work.
4.2L , CAI, BBK 65MM throttle body, 30lb injectors, SSM ported intakes, FLEX 1/2" spacer, RPM big valve heads, Comp roller rockers and cam, ASP-underdrive pulley, GT rear swaybar, & Quad Shocks, Full MM Coilover conversion, 17" Grey Torque Thrust wheels, FMS Aluminum driveshaft 8.8 rear w/ 3.73 gears, Tri-Ax Shorthrow shifter & SPEC stage II clutch w/ aluminum flywheel
Horse is offline   Reply With Quote
Old 07-05-2007, 08:17 PM   #7
Region: New Mexico
TCCoA.com - Thunderbird & Cougar Club of America
Good source for 3.8 SC motors. I know this is late but any one else searching it may be of use.
Drnaline is offline   Reply With Quote
Old 09-09-2007, 03:10 PM   #8
i have a 95 stang very blown up 3.8 and a wrecked 90 tbird sc i want to put the engine and trans in my stang from the sc any comments?
tow4snojr is offline   Reply With Quote
Old 09-10-2007, 10:57 PM   #9
Region: New Mexico
The electircal is the only hassle. It will fit though.
Thunderbird package? andreas Classic Mustangs 7 07-03-2007 08:22 PM
Thunderbird supercharger swap... crazeflier07 Pre-2005 V6 Mustang 10 05-04-2006 02:26 PM
No more Thunderbird 04MonteSS General Car Discussion 16 04-02-2005 08:23 AM
Thunderbird S/C swap veesix Pre-2005 V6 Mustang 10 09-22-2004 06:27 PM
03:50 AM
