Tuner questions. - Mustang Evolution
Old 07-30-2006, 12:06 AM   #1
Tuner questions.
So lately ive been doin some reading on tuners and chips and am borderline just ordering an SCT tuner. However, im not sure how it works. Can anyone tune their car? Or do u gtta have some experience to do it? I mean im pretty good with computers but not to savvy on my stang (YET!!!!!!). Am i better off just gettin a chip installed or get it tuned at a shop or should i get the tuner? RPMOUTLET.com is offering a UDP system with the belt and with and SCT tuner for 499.99... is that a good deal http://rpmoutlet.com/newv6m.htm? Any other suggestions for tuners or w.e would be greatly appreciated. Im a lil lost (as usual) so i figured id come to the pros. Thnx in advance guys.
iceman08 is offline   Reply With Quote
Old 07-30-2006, 12:25 AM   #2
Re: Tuner questions.
#1.) Avoid RPM outhouse like the plague.
With that said. Anyone can tune their car with a SCT tuner IF they know how to properly adjust timing, fuel, etc, etc. If you are not car savy, I would say do NOT try to tune the car yourself as you will almost certainly blow it up. It doesn't matter that you know computers, fuel and timing curves are something very unrelated to computers.
You would be much better off getting the SCT XCal 2 Tuner because it is much easier to update than a chip. You just tweak parameters and re-upload it into your car and you are all set. A chip requires you take it out, reburn it, put it back in. Plus there are a lot of shops that do SCT tuning (VMP is over near you in florida somewhere).
The deal you are seeing from RPM outhouse looks good on the surface until you realize you have a tuner with no tune on it. Then you need to go to a shop where they will charge you 100+ for a basic setup. However, if you buy the XCal 2 from VMP (one of our sponsors), you are looking at $399 and that includes 3 custom tunes for your car so all you need to do is upload the one you want to use. Oh yeah, that is the other benefit...you can store 3 different tunes on the Xcal, so you can hot-swap from a tune for high MPG and then one for racing....just plug in, upload, go.
Check out this thread starting with post 25 and you will get a lot of questions answered. http://www.mustangevolution.com/foru...highlight=xcal
If there is something not answered in my comments or that thread, throw out your question and either someone will answer it, or I will send VMP in here to give you the proper answer.
Old 07-30-2006, 07:10 PM   #3
Thnx for the insight and the heads up on rpmoutlet. I ordered a K&N intake from them and it came out good, so i figured id go with them. (A lil off topic but hows their UDP kit look to u). So if i buy the tuner with preloaded tunes, is it ez to load them in? Or is it creating the tunes that requires knowledge? I mean, how difficult is it to learn the device? And i read in a few places (correct me if im wrong) that they can email u the custom tunes and u can store it on ur comp, then syncronize the comp with the tuner and then upload it to the car? Is this true and is it ez? Also, is there any software and hardware out there that u can use to connect ur laptop to ur car to do diagnostics or maybe even tune??? im just throwin it out there cuz it seems pretty possible. Thanx again for ur insight.
Old 07-30-2006, 07:27 PM   #4
If you buy a tuner with preloaded tunes for your car, it's very easy to tune your car. All you have to do is plug in the connector to the computer port under your driverside dash and press a few buttons and follow the instructions, very easy to do.
And yes, you can connect the tuner to your computer with a normal usb cord in order to upload datalogging or to download new/updated tunes and updates for the software on the tuner.
Old 07-30-2006, 07:45 PM   #5
Like Lowflyn said, yes, you can connect the XCal 2 to your laptop with a simple USB cable and datalog a number of parameters and review it all later. It will also allow you to datalog the Air fuel if you buy a wide band commander at a later date. It is a very versitile device.
As for changing tunes...it takes about 5 minutes if you take your time. After a few times through, it will probably take you about 1-2 minutes.
Old 07-30-2006, 07:46 PM   #6
I can swap tunes before the tank fills up with gas, not hard at all once you learn how.
Old 07-30-2006, 07:50 PM   #7
DarkShadow's Avatar
Send a message via AIM to DarkShadow
Lol, the longest part is just loading the new one.
DarkShadow is offline   Reply With Quote
Old 07-30-2006, 07:50 PM   #8
^^ Exactly.
Old 07-31-2006, 09:17 AM   #9
We can match the RPM outlet deal, and we are actually a real tuning shop with several dynos and experience tuning Fords, especially V6s (its hard to find shops with V6 experience).
On a stock V6 you'll see a gain of 7-12 HP and 7-12 TQ at the wheels. The power is gained under the curve too (not just peak) so its a very noticeable difference. The speed limiter can be removed too. If you have an auto the car will shift much better with our tune. Throttle response will also be much better.
Its very easy to flash the car with the x-cal2, and you can call us if you have any questions while doing it.
Justin Starkey
2007 Shelby GT500 705RWHP/708RWTQ
2000 Mustang 3.8 A4 TT 450RWHP/475RWTQ 10.996@127 17psi stock 3.8
2006 F250 CC 4x4 6.0L 14.3 @ 93
2006 Mustang 4.0 M5 Vortech 13psi 395RWHP/374RWTQ wife's car
justin00stang is offline   Reply With Quote
Old 07-31-2006, 09:47 AM   #10
Definatly go with Justin if you want a tune. He is great at tunning our cars, and he will wok with you to get the most out of your car.
Intermision is offline   Reply With Quote
Old 07-31-2006, 01:21 PM   #11
Herbstang's Avatar
+ 1 Justin tuned my V-6 !! The man knows his tunes
Old 07-31-2006, 09:03 PM   #12
Cool Re: Tuner questions.
I really appreciate everyones input on the subject. And thanx to smurfin and justin for ur input at thoughts. Im definitely gonna b ordering from vmptuning when im ready to get it. Is there anything else i should kno. Again guys, thanx, u were all really helpful and insightful.
Old 08-08-2006, 08:09 PM   #13
Region: Iowa
Send a message via AIM to Horse Send a message via Yahoo to Horse
Hey what's wrong with RPM? Er.. wait, is that different than RPM as in Redlined Performance Mustangs?
Cause I've gotten my heads and gaskets and cam through That RPM and he's awesome.
4.2L , CAI, BBK 65MM throttle body, 30lb injectors, SSM ported intakes, FLEX 1/2" spacer, RPM big valve heads, Comp roller rockers and cam, ASP-underdrive pulley, GT rear swaybar, & Quad Shocks, Full MM Coilover conversion, 17" Grey Torque Thrust wheels, FMS Aluminum driveshaft 8.8 rear w/ 3.73 gears, Tri-Ax Shorthrow shifter & SPEC stage II clutch w/ aluminum flywheel
Horse is offline   Reply With Quote
Old 08-08-2006, 08:17 PM   #14
slvr2000stang's Avatar
Yes it's a different place.
Custom Delk motor now DOA
2003 SVT Lightning #1059 of 4270
2000 Vert 4R70W
Only buy from vendors that test and stand behind their products
slvr2000stang is offline   Reply With Quote
Old 08-08-2006, 08:30 PM   #15
Yes, RPM Outhouse is properly known as RPMOutlet ... They suck donkey balls. Your RPM is
Old 08-10-2006, 02:25 PM   #16
Pony Ride's Avatar
I'll throw in another for Justin at VMPTuning.com..... The difference was amazing, and the x-calV2 tuner was very easy to use.
Pony Ride 2!! 2007 Grabber Orange GT Premium with 5-speed manual transmission
Pony Ride is offline   Reply With Quote
HELP New or Used TUNER? oldtexasdog 2005-2010 Mustang GT 3 06-24-2010 03:30 PM
tuner upton7 1996-2004 Mustang GT 13 02-21-2010 08:37 AM
Which Tuner to Get? mxw1090 Pre-2005 V6 Mustang 5 06-19-2009 11:46 AM
Tuner upton7 1996-2004 Mustang GT 2 05-16-2009 11:56 AM
Why get a tuner? Laser 1996-2004 Mustang GT 10 06-11-2007 07:31 PM
10:57 PM
