Need to know location for main engine ground asap... - Mustang Evolution
Old 08-03-2006, 03:18 PM   #1
DarkShadow's Avatar
Send a message via AIM to DarkShadow
More importantly, where the ECU ground is located on the engine if possible. If not, just tell me where the best engine block ground would be.
DarkShadow is offline   Reply With Quote
Old 08-03-2006, 08:47 PM   #2
DarkShadow's Avatar
Re: Need to know location for main engine ground asap...
NM, found a good one.
Old 08-03-2006, 09:02 PM   #3
Well share for future reference
Old 08-03-2006, 09:14 PM   #4
DarkShadow's Avatar
Ended up not using the block. I just used a good body/chassis ground. The main thing was putting it in an area where there would not be a incorrect ground offset that would interfere with the Lambda measurement.
Old 08-08-2006, 02:02 AM   #5
97Stallion's Avatar
The factory grounding point is on the driver's side mounting bracket to inside the driver's side wheel well.
Living one day at a time!
New job/location Scut95 The Bar 8 06-05-2008 11:40 PM
IAT Sensor Location??? XxViSiOnxX Pre-2005 V6 Mustang 11 10-27-2006 06:53 PM
Stereo ground wire location Crispy Mustang Audio & Video 4 10-19-2004 11:02 PM
Location Location Location Ken The Bar 9 08-07-2003 08:51 AM
03:36 PM
