2000 mustang V6 not starting - Mustang Evolution
Old 05-06-2010, 09:56 AM   #1
j4gwig's Avatar
i have a 2000 mustang that was hit in the front corner,the air bag did go off,i have replaced the damaged parts, all but air bags. tried to start it last night and all it does is crank will not start, i checked the fuel shut off relay in the trunk and it is in the down position, any ideas???
j4gwig is offline   Reply With Quote
Old 05-06-2010, 09:59 AM   #2
racefan966's Avatar
Region: Idaho
Re: 2000 mustang V6 not starting
Like I said I sent you message so get back to me and we will see if we can get this thing running.
racefan966 is offline   Reply With Quote
Old 05-06-2010, 11:46 PM   #3
j4gwig's Avatar
OK i am getting fire to the plugs but no fuel to the rail,could it just be a bad fuel pump or is there another problem I need to check before dropping the tank
Old 05-07-2010, 07:06 AM   #4
MonteCitan's Avatar
when you first turn the key on, door open, do you hear the fuel pump prime?
If no.. get under the hood, and swap the fuel pump relay with another relay like the cooling fan relay (they are marked in your Owner's manual and probably under the fuse box cover, as well) Sorry I can't remember anymore which ones they are off the top of my head
If there are any fuses (there are) check them to see if they're blown
If the above don't work.. :
Is your 'theft' light flashing?
if it's ok, then try disconnecting the fuel cutoff switch, and jumping it with a paperclip or jumper wire (don't bend the terminals/force it in, just make contact) then try again, see if the pump primes..
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 05-07-2010, 07:23 AM   #5
there is a cut off on the fuel pump in trunk, its a button and I think its behind one of the tail lights, it can be shut off and you need to turn it back on.
Old 05-07-2010, 07:47 AM   #6
racefan966's Avatar
Region: Idaho
Ok great you have spark to the plugs what color is it? Also you say you have fuel to the rails so now I need you to check the pressure needs to be 35 to 55 psi to start and run. Running pressure will be around 40. Again message me with what you find and we will go from there.
Old 05-07-2010, 08:30 AM   #7
j4gwig's Avatar
ok i had it running on starting fluid it is a fuel problem for sure, I jumped the relay in the trunk it did not help and there is not a relay in fuse panal under the hood just fuses and they are good, the theft light flashes when key is off but when you turn the key on it goes off
Old 05-07-2010, 09:00 AM   #8
j4gwig's Avatar
Ok I have another problem. I bought my kid a 95 GT conv,5,0 automatic..the tranny was falling off, bellhousing bolts where all loose and missing we fixed that but now we have a bad vibration at idle and when you kick the passing gear in it feels like its coming apart, the vibration is there rather in part or in gear, I had a freind tell me the balancer sliped is that possible
Old 05-07-2010, 09:19 AM   #9
if its an engine harmonic balancer issue it would do it while in neutral, might be something with the TQ converter etc being off since the transmission was not correctly installed and was loose.
Old 05-07-2010, 09:29 AM   #10
j4gwig's Avatar
it does do it in neutral in park all the time really it seems to go away when you give it a little gas but if you try to kick in passing gear its really bad
Old 05-07-2010, 10:55 PM   #11
racefan966's Avatar
Region: Idaho
Check for a bent flexplate. The other car sounds like it has a bad fuel pump so look forward to dropping the tank and replacing it.
Old 05-07-2010, 11:41 PM   #12
j4gwig's Avatar
yep I think it is the fuel pump im getting power all the way to where the wires run into the pump,and far as the 95 GT fixed it, it was the Harmonic Balancer went bad
Old 05-08-2010, 03:37 PM   #13
racefan966's Avatar
Region: Idaho
Wow the other end of the engine. With the trans problems that was my first thought.
Old 05-08-2010, 10:23 PM   #14
j4gwig's Avatar
yeah running great now,buttt the 2000 changed the fuel pump and did not help,started going through the fuses again and check for broke wires,,it was a ground wire behind the passenger headlight was broke off from the wreck..
Old 05-10-2010, 12:53 PM   #15
j4gwig's Avatar
help with sealing timing cover on a 1997 4.2
I had to change the timing cover on my kids 4.2 F150, now i cant get it to stop leaking, should i have not put sealant on it,could that be the problem, I put the sealant on the block and not on the cover, should i do both or none at all plz help if anyone has had this problem.
2000 mustang
help starting new Mustang Club 2007STANG Pre-2005 V6 Mustang 8 08-21-2009 11:41 AM
Could the v6 mustang days be over?...I'm starting to wonder sonic04edge General Mustang Discussion 8 09-07-2008 05:59 PM
2000 v6 mustang donnie Pre-2005 V6 Mustang 26 05-28-2006 05:44 AM
1998 Ford Mustang Starting Problems redv6stang Pre-2005 V6 Mustang 4 09-25-2005 02:17 PM
09:04 PM
