LOK question - Mustang Evolution
Old 05-06-2010, 07:41 PM   #1
LOK question
I was looking up a posi rear end. I already have the 8.8 and 3.73 gears on the way. Would this limited slip differential work? Is there ne thing else ill need?
Ford Racing 8.8" 31 Spline Traction - LOK Limited Slip Differential at AmericanMuscle.com - Free Shipping!
Stumper is offline   Reply With Quote
Old 05-06-2010, 09:41 PM   #2
Jordan's Avatar
Re: LOK question
depends on the year of the car you have but that is what you need for the posi.
Red 1998 Mustang V6 5-Speed. Flowmaster True Dual Glasspack Exhaust, AM Cold Air Intake, Black Chrome Cobra 17x9 fronts, 17x10.5 rears, short throw shifter, rear bumper inserts, billet grill top and bottom with pony insert, chrome shorty antenna, chrome shift knob, halo headlights-HID's 8000k, smoked fog lights-HID's 8000k, custom radio and speakers, Eibach Pro-Kit lowering springs
Jordan is offline   Reply With Quote
Old 05-06-2010, 09:55 PM   #3
Re: LOK question
that one will NOT work with the stock axles. the stock 8.8 comes equipped with 28 spline axles and that one is for 31 spline axles. to get it to work, you would need upgraded axles which you shouldnt really need unless youre putting down serious power.
tigerfan2771 is offline   Reply With Quote
Old 05-06-2010, 09:58 PM   #4
Re: LOK question
is your 8.8 not coming with a differential? it already has a limited slip differential in it from the factory. you could just rebuild it as well.
Old 05-06-2010, 10:22 PM   #5
Re: LOK question
hmm i think i have myself all mixed up. Explain what i want / need if i want a 8.8 rear end with 3.73 gears and limited slip diff....
Old 05-07-2010, 12:05 AM   #6
Re: LOK question
i think with a little research and help from my friend i figured out what i need. Take a look at this for me..
Speed Concepts - TO1024 - 2005-2010 Mustang GT 8.8 Rear End Axle takeoffs with 3.55 gears and T-lock (also direct fit on V6 models)
Old 05-07-2010, 07:26 AM   #7
Re: LOK question
you need a 7.5 inch Tlok or Aurburn differential. its a GREAT idea to install one while you do gears as its the same amount of work (pretty much) since the stock unit has to come out and the ring gear has to be removed from it so.... just stick the new one on the table for reassembly lol, shouldnt be but like 25 bucks extra to install a new tlok as they have to double check shimming it.
Old 05-07-2010, 07:43 AM   #8
racefan966's Avatar
Region: Idaho
Re: LOK question
If you have any HP you will need to upgrade to the 8.8. Otherwise the 7.5 will do fine.
racefan966 is offline   Reply With Quote
Old 05-07-2010, 09:30 AM   #9
Re: LOK question
yea 7.5 is mostly fine up to around 300rwhp~ but it doesnt take much at any hp level if the conditions are right to snap a spider gear in the rear end (auburn diff's are better for this reason) as the spider gears is the weak link in the 7.5 rear end.
Old 05-07-2010, 09:58 AM   #10
Re: LOK question
But he already has the 8.8. Those already come with a t-lok right? No need to upgrade to 31 spline axles and a 31 spline t-lok.
Old 05-07-2010, 12:48 PM   #11
Re: LOK question
ah you are correct, I missed that... I saw V6 and though 7.5 as thats what they all have stock~ yea no need to upgrade anything bug gears, I would go ford racing NOT motive/etc as other brands can whine. ONLY let someone install that knows what they are doing else you may end up with whine that they say is "normal"... thats BS.
Old 05-07-2010, 02:24 PM   #12
Re: LOK question
yes definately go ford racing. i did motive because they no longer have ford racing for the 7.5 and there was no whine. but it is better to do the rear end the right way the first time. also, make sure the axles are straight, bearings are good, and that the differential doesnt need to be rebuilt. you dont want to have pay for the work to be done twice.
Old 05-07-2010, 04:54 PM   #13
Re: LOK question
Yah the 8.8" comes with the 28 spline tlok from the factory...I am 100% confident that the unit you're buying has the tlok in it. You probably won't need 31 spline axles or a 31 spline differential. There are plenty of high hp/tq v8 guys using the 28 spline stuff and having no problems.
As said, you could upgrade to taller gears. Just make sure you order gears for an 8.8" rear. I do believe you can still get 8.8" gears from Ford Racing, the 7.5" you cannot.
Old 05-07-2010, 06:14 PM   #14
Re: LOK question
Okay awesome guys thanks..... Once i get my exhaust installed in a week or soo, im gonna tackle the rear end.... Ill take some pics if yall want some... ty again
Old 05-07-2010, 06:48 PM   #15
Re: LOK question
No problem, definitely post pics if you think of it...always a great reference.
Old 05-07-2010, 10:51 PM   #16
racefan966's Avatar
Region: Idaho
Re: LOK question
Yea saw V6 thought the same. Go either Motor sport or Tom's Diff.
Old 05-16-2010, 11:26 AM   #17
Re: LOK question
Can you reuse the same drive shaft when switching to 8.8 from 7.5?
Spitfire_31 is offline   Reply With Quote
Old 05-16-2010, 11:58 AM   #18
Re: LOK question
I believe you can. You might need to change the yoke or the parts where it connects.
Old 05-17-2010, 05:43 PM   #19
Re: LOK question
Just make sure if you do take the driveshaft off, mark the bottom of it (probably the front near the transmission), as well as the bottom of the extension housing of the transmission with a sharpie or heavy duty marker so you know the correct placement when re-instaling it.
Old 05-17-2010, 06:49 PM   #20
Re: LOK question
Yep ill take pics no worries. The drive shaft works with the 8.8, i just need to buy a flange. Once i get my body kit on and exhaust finished. I should be ready to tackle the Rear end swap.
Waiting for damn parts is brutal. Also working 24 out of 30 days a month makes it so hard to finish things.
t-lok question BigL34461 Pre-2005 V6 Mustang 3 11-08-2006 09:56 AM
t-lok tim11 Pre-2005 V6 Mustang 15 11-06-2005 05:07 AM
T-lok question I_luv_HP&trq Pre-2005 V6 Mustang 9 10-02-2005 11:58 AM
Another 4.10s and T-Lok question soon2bfastr232 Pre-2005 V6 Mustang 15 02-08-2005 08:38 PM
t-lok chevykiller Pre-2005 V6 Mustang 6 08-26-2004 02:35 PM
04:53 PM
