Used Turbocharger - Mustang Evolution
Old 08-13-2006, 03:04 PM   #1
NotoriousSPG's Avatar
Send a message via AIM to NotoriousSPG Send a message via Yahoo to NotoriousSPG
Used Turbocharger
My friend is selling me his used Turbonetics t4 model turbocharger. I have a stock v6 2000 with nothing but a flowmaster bolted on. any tips? suggestions? and does anyone know how much of a boost the turbo will give me? thanks!
NotoriousSPG is offline   Reply With Quote
Old 08-14-2006, 07:43 AM   #2
Re: Used Turbocharger
after you fab it up the stock block will be ok at 10-12 psi depending on tune, its all depending on the tune.
Old 08-14-2006, 07:56 AM   #3
rydog's Avatar
Send a message via MSN to rydog
It is going to take lots of work to fab everyting you need to mount the Turbo unless it came off of a V6. This web site should help out a bit this gut builds custom turbo kits just for V6 mustangs.
TMA TURBO
97 V6-GT40 turbo-42#rs-BA2800 MAF-4.10's & tlok-254rwhp-369rwtq
Turbo'd by-TMA Turbo(http://www.tmaturbo.com/)
Tuned by-Dyno Tuned Performance(http://www.dtpracing.com/)
rydog is offline   Reply With Quote
Old 08-14-2006, 05:01 PM   #4
TMA TURBO
well yeah its a turbo kit and it comes off of a v6. keep in mind, im a car building newbie. so I dont know what fab ing something up means. I also dont know about the tune, its stock 2000 v6 3.8l
Old 08-14-2006, 05:58 PM   #5
KyleUSAF's Avatar
Send a message via AIM to KyleUSAF Send a message via MSN to KyleUSAF
well, you have the turbo..but do you have anything else? There is a ton of stuff that goes into making your car turbo'd. You'll have to have tubing that fits your car (fabing means fabricating, which is like building specifically for your car), then you'll have to have new fuel injectors, fuel pump, intercooler (probly) and so on. Just having a turbocharger does not mean your car is anywhere close to being turbo'd. If your serious about it this is a great place to learn about it. Darkshadow recently finished turboing his v6 stang and i'm sure he can tell you all about the little costs and details that are involved.
Originally Posted by Darkshadow
I could say nothing for my complete awe. He then. confidantly, purchased the gallon.
KyleUSAF is offline   Reply With Quote
Old 08-15-2006, 04:51 PM   #6
ok sounds good, but will just adding the turbo kit itself result in any change in HP? Like will I feel a difference?
Old 08-15-2006, 06:55 PM   #7
I_luv_HP&trq's Avatar
Send a message via AIM to I_luv_HP&trq Send a message via MSN to I_luv_HP&trq
You serious? The whole point in adding forced inductioin is to make more hp and torque.
The power you make depends on how much boost your wastegate is set for. 4 psi will get you between 220-245 rwhp and 10 psi 320-350 rwhp. Those are average gains for a stock 99-04 V6.
Since my V6 felt faster with all the bolt ons, I'm sure you'll feel the difference even with only running 4 psi.
99 Cobra: flowmasters, 18x9.5 cobra R's, soon to be tuned and geared. daily driver
99 V6:in avatar, Mac Cai, true duals/flowmaster 40's ,UDP, custom tuned, bullitt suspension 18" wheels...taken by mother nature
I_luv_HP&trq is offline   Reply With Quote
Old 08-16-2006, 03:30 AM   #8
Im tellin ya bro, im new to the car tuning scene.. haha how can I get it to 10 psi?
Old 08-16-2006, 07:33 AM   #9
rydog's Avatar
You have to change the wastegate spring to get more or less boost. You can use your stock injectors, fuel pump and MAF ( Mass air flow) with 4#'s of boost if you go any more you will have to change all of the above to meet the fuel demands of more boost. Go to the website I have linked in my previous thread and it will answer alot of your questions
Old 08-16-2006, 03:11 PM   #10
DarkShadow's Avatar
Send a message via AIM to DarkShadow
I don't want to sound like an ***, but you should do a LOT of reading and research before you go and put anymore money into this. This is no easy bolt on project. Even if you do get all the equipment, get everything fabbed up, which will be very difficult unless you just buy piping from Andy on TMA, get it all installed, and check for all the things you might have missed, you will still need to get it tuned. I have had my car done since April and I'm still working on getting the tuned straightened out. If you have someone who know what they are doing in your area, it may not be as hard for you on that part.
But if you don't know how to increase PSI, you really need to do some reading.
DarkShadow is offline   Reply With Quote
Old 08-16-2006, 07:09 PM   #11
allright, where can I go to read up and learn about all this?
Old 08-16-2006, 09:11 PM   #12
tmaturbo.com
Old 08-16-2006, 09:52 PM   #13
http://www.turbomustangs.com/turbotech/main.htm
Ray Hall Turbocharging - TurboPower java calcultor
Welcome to Turbo Mustangs.com
supercharger vs. turbocharger jimmy_beaner Pre-2005 V6 Mustang 23 12-21-2007 05:11 PM
Big Turbocharger JROC Pictures and Videos 6 09-24-2006 06:38 PM
12:18 PM
